03-27-2011, 10:32 PM | #133 |
Rep 1,543
03-27-2011, 11:01 PM | #134 |
The One And Only
15
Rep 398
Drives: 2006 TiAg ///M Roadster
thanks! any way u could toss up some pics of your car?
04-16-2011, 10:27 PM | #135 |
Penfold, shush!
Rep 132
I'm planning on an 18x9 F and 18x10 R setup. 07 Z4MC
I have the option to specify my ETs, so I'll ask the experts. I would *like* to get 255s in the front and 285s in the rear. This is for a track setup on stock suspension (at the moment, though I doubt I'll ever drop the car more than half an inch, ever). The question is: what ETs should I get for those wheel sizes, and what aspect ratio of the tires to get it close to stock? I'd do the math but the last time that happened, I...well, MATH IS HARD. |
04-17-2011, 07:37 AM | #136 |
Rep 632
18x9 et42
18x10 et30 If in doubt, go a tad higher on the offsets so you have the option of using thin spacers to get it perfect. Lots will depend on tire brand and model and the specific shape of the tire. Expect rubbing - even with dead on perfect offsets, 255/40 and 285/35 is a tight fit on this car - trust me
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
04-20-2011, 10:15 PM | #138 |
Rep 494
anyone know if these will fit...owner say will fill on z4mc
VMR VB3 Bolt Pattern: 5x120mm Center Bore: 72.6mm 19"x8.5" +40mm Front 19"x10.0" +25mm Rear Thanks in advance!
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| |
04-21-2011, 04:49 PM | #139 | |
Rep 5,329
as is the fonts will looken sunken in the arch and wont look ideal imo. i love +32 offset with alittle camber upfront.... PERFECT!!
04-21-2011, 07:49 PM | #140 | |
Penfold, shush!
Rep 132
04-21-2011, 11:14 PM | #142 | |
Rep 494
04-24-2011, 10:49 PM | #143 |
Rep 4,531
Hey Guys.
I'm looking for autocrossing wheels. I want to go 225s in the front and 255s in the rear. Can I go 18x8 ET 35 in the front and 18x9 ET 20 rear? |
04-28-2011, 10:32 AM | #144 |
Rep 494
Will these fit?
Fronts: 19x8.5 et 32 Rears: 19x10 et 25
04-30-2011, 04:56 AM | #145 |
Rep 5,329
get that rear to 9.5" and your talking the perfect z4m setup in 19" sizes :-) this will be flush all round and will be able to take small increments of lowering also :-) tyre choice is paramount also.
05-12-2011, 02:55 PM | #147 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Fronts are like 15mm too aggressive with stock suspension/camber setup.
The rears are pretty aggressive too and you will probably have to pull fenders to prevent rubbing. These are very close offsets with Crfine's TE 37 SLs... which are seriously aggressive. Last edited by Daemonblitz; 05-12-2011 at 03:02 PM.. |
05-12-2011, 03:16 PM | #148 |
instagram 997turbotom
279
Rep 7,377
05-17-2011, 12:13 AM | #149 |
Rep 1
Hello everybody, I'm new here, I'm from Belgium and I just bought a 2006 Z4 M Coupe. I have found some nice BBS LM's with these specs:
Front 19 x 8.5 ET38 Back 19 x 9.5 ET20 Will these fit without rubbing ? Is the wheel at the back going to stick out of the fender ? (I hope not) And what would be the perfect tires for these wheels ? Already thanks and I hope my English isn't too bad |
05-17-2011, 10:46 AM | #150 |
Rep 1,031
Hey guys
I have a tire shop putting together a winter tire package for me and they state that the following will work. I am doubtful after reading this thread that a 17" will fit over the brakes. What do you guys think? It is for a Z4M. Thanks 17" rims with 40 ET 225/45/17 tires and 225/5017 tires |
05-24-2011, 01:35 PM | #151 | |
Commander
221
Rep 850
As for tire sizes, if you want a squared setup the correct tire size for 17"s is 225/50/17 all around. 225/45/17 is too thin of a sidewall. You never mentioned the width of the rim, that is important too when you mention offset. If they are 8" you are fine in the front but you will need a significant spacer at the back to keep the wheel from being tucked under the fender. |
05-24-2011, 03:25 PM | #152 | |
Rep 10,309
Drives: A///MERICAN!!!
05-26-2011, 06:07 PM | #153 |
Rep 1,031
Thank you BTM & Daemonblitz for your posts. I will try and stop by the guy's shop Saturday to do a test fitting and will report back.
I don't know the width of the tires, he didnt mention that but I am going to assume at least 8" BTM ... How are those rims to clean? They look good! |
06-27-2011, 08:35 PM | #154 |
Rep 8
If someone could help me out, I'd appreciate it. I'm pretty new to this site, as I have just been a spectator every since buying my z4m coupe. However, I have come across some ccw wheels and want to know if they would fit.
18x8.5 et38 fronts 18x10.5 et19 or 18x10 et18 rears Thanks in advance! |
