08-11-2014, 03:09 PM | #23 |
Rep 1,530
Ok, here's the 4 pin connector. If there is an intermediate connector so I can get it to connect to the yellow connector, do you know what that part number might be?
08-11-2014, 04:50 PM | #24 |
Rep 1,530
Problem solved. The intermediate connector was still on my original seats. Now, the only light that is on is the dash passenger seatbelt/airbag light for the passenger side. The passenger airbag light on the center console used to be on even though the airbag was turned on with the key by the passenger side door. I think all I need to do now is someone to reset the error code. Thanks for the help!
08-11-2014, 05:24 PM | #25 |
Rep 273
Glad to hear you tracked it down the missing wiring. Make sure you pass that info along if you resell your old seats, as that purchaser is going to be up against the same thing ...
08-12-2014, 08:03 AM | #26 | |
Rep 12,565
