      02-24-2012, 08:34 AM   #1
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
12.5mm spacers with what length studs?
So, i just bought a Stoptech BBK. They won't fit behind stock wheels without spacers according to my garage when they tried installing them.
They had a used set of 12mm spacers there and using them they said that it clears the wheel spokes so i've decided to buy a set of Turner's 12.5mm wheel spacers.
Since i'm relatively frequently removing the wheels i thought i'd also convert them into a stud setup. Now Turner sells 75 and 90mm long studs, which one's should i buy? I've emailed them with this twice already but got no reply yet...
Spacers i'm gonna buy: http://www.turnermotorsport.com/show...l-spacers-pair
Studs i'm trying to decide about: 75mm http://www.turnermotorsport.com/p-11...-mini-etc.aspx and 90mm http://www.turnermotorsport.com/show...0-e92-mini-etc
I've also read this, http://www.turnermotorsport.com/t-wh...yclopedia.aspx which is Turner's article about wheel spacers and if you scroll down where it says "Wheel Spacers With Wheel Studs" it mentions that you should calculate the length of the studs you need by factoring in the spacer thickness but also the brake hat thickness as well. Still confused though, don't know how thick the Stoptech brake hat is.
Anyone else has studs and spacers? Should i just get the 90mm and be done with it??
*edit: If i get the 90mm ones and then buy different wheels in the future that don't require spacers will the 90mm studs still work safely? I mention this because on Macht Schnell's website (http://www.machtschnell.com/product/...conversion-kit) it says this about about their 90mm studs "- 90mm length allows for spacer thicknesses (up to +20mm) to be used without changing studs (NOTE: a +5mm spacer minimum is required for installation)"
      02-24-2012, 09:55 AM   #2
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Just had a reply from Turner Motorsport saying that 75mm will be fine. If anyone wants to add anything to the thread though feel free to do so.
      02-24-2012, 11:11 AM   #3
Beedub
hi ga41 75mm studs will be perfect for your needs...... they will fit nice and flush :-)
ga41 if you need any info Re spacer/studs/nuts then drop me a pm as i went through this pretty comprehensively on my BBK install....
i must advise against you running a 12.5mm spacer on the front of your stock rims, this will make your front offset too aggressive.. remember the stock is ET42....
      02-24-2012, 11:14 AM   #4
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Hi dude, so you think 75mm is enough for the aforementioned spacers? I am literally about to order them
      02-24-2012, 11:17 AM   #5
Beedub
Ga41 this is how it will look...
you'll LOVE these once they are installed, its right up their with my favourite mods, the kic wheel nuts are a thing of total awesomeness.... but sadly rather overpriced....
      02-24-2012, 11:18 AM   #6
Beedub
yes definatly fine with the spacers no issue at all, upto to 12.5 is pretty much perfect for the 75mm studs with TOTAL thread engagement, check out my photos, but on stock rims not a good idea......
im assuming your running stock rims , if not then ignore this comment and order away..... hope this helps
      02-24-2012, 11:21 AM   #7
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
What do you mean not a good idea?
It's going to be stock wheels for me. I actually like them for one but mostly it's because of cost, spacers + bolts or even studs is much cheaper than a new set of wheels!
      02-24-2012, 11:25 AM   #8
Beedub
on the stock rims you need a 10mm spacer :-) 12.5 is too much, this will take you to ET32, with alittle camber to tuck in the rim you'll have a great looking and performing setup..... your chosen route would be ET29.5 which is too aggresive for the z4m front unless you plan to run stupid camber
      02-24-2012, 11:27 AM   #9
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Well i do have a set of camber bolts laying about...
      02-24-2012, 11:43 AM   #10
Beedub
i promise you even at et32 the rim with stick out at the front without alittle camber, et 29 will require more than you want for the street driven vehicle :-)
      02-24-2012, 11:48 AM   #11
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Well, no going back now, i've ordered them and I shall see for myself how it works when they get here. :P
      02-24-2012, 11:56 AM   #12
Beedub
ok no probs, you'll see what i mean shortly ;-)
      02-24-2012, 05:46 PM   #13
Shipkiller
Shipkiller's Avatar
Drives: Me
I have 10mm spacers on the rear with 75mm studs and they fit well.
The only thing you need to watch for is thread engagement. For a properly fitting fastener (nut) the minimum number of threads exposed should be two (2) for a non-nylock fastener. For nylock fasteners (any fastener that has plastic/nylon etc. built into it), it is acceptable to have the stud/bolt flush with the end of the fastener.
      02-25-2012, 12:36 AM   #14
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Gotcha.
      06-24-2012, 06:54 AM   #15
Swashplate
Swashplate's Avatar
Drives: in Anger.
Where did you get them?
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      06-24-2012, 09:23 AM   #16
Beedub
broker... which bit are you asking about??? the complete wheel nut/stud setup was purchased from turner.....
      06-24-2012, 01:27 PM   #17
Swashplate
Swashplate's Avatar
Drives: in Anger.
Ahh I see. The studs look grey. I thought they only came in black.
1217/1815
!!! BOILER UP !!!
      06-24-2012, 01:35 PM   #18
Swashplate
Swashplate's Avatar
Drives: in Anger.
Where in UK are you ? I am currently in Fullham till Wed.
1217/1815
!!! BOILER UP !!!
      06-24-2012, 02:02 PM   #19
Beedub
im in birmingham, a good 2hrs from you otherwise id arrange a meet up a local pub for chat chat and general drunkness. lol
      06-24-2012, 03:07 PM   #20
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Really? I run 12.5mm front and rear and it's not aggressive enough... Unless you're talking about fitting the BBK...
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      06-24-2012, 04:09 PM   #21
Beedub
the OP has already discovered rub issues as per what i originally said ;-)
      06-24-2012, 04:27 PM   #22
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
It's true, i have. Perhaps it might be because the Yokohama AD08's i have run wider than other tires though...
An example of what that small plastic protrusion of the wheel well has done to my tires:
