08-26-2014, 12:04 PM | #1 |
Rep 60
Seat ideas for a moddified z4m I am buying
Ok, I am buying a modified Z4M from a forum member on here and I went to SO CAL to drive the car this past weekend and I could not get into the racing seat. It was meant for a thinner person. Frankly a little hurtful I might add.
So the car is a track and street coupe, so I need to ditch the racing seats, but was looking for something a little more comfortable to fit a 38 and could be both a track seat and a street seat that uses a 6 point harness. Any ideas? |
08-26-2014, 01:13 PM | #2 |
Rep 231
I have the same issue. Somewhere I say someone that installed some Porsche Gt2 seats. They looked great. Can't seem to find it now.
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
08-26-2014, 02:13 PM | #3 |
Rep 12,565
Recaro Profi XL might do the job but not sure if it will rub against door cars.
08-26-2014, 03:27 PM | #4 |
Rep 60
08-26-2014, 04:34 PM | #5 |
Rep 12,565
I say you just deal with the door card rubbing. It's not the end of the world and not a problem specific to the Z4. I've seen this on 1/3-series all the time.
08-26-2014, 05:52 PM | #6 |
Rep 25,989
Edirb
Recaro Sportster (not too sure on width) Status
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
08-26-2014, 09:57 PM | #7 | |
Rep 12,565
Sportster isn't 5/6 point compatible |
08-27-2014, 01:48 AM | #8 |
Rep 60
08-27-2014, 08:55 AM | #9 | |
Rep 12,565
Sparco Evo - tight waist, good lumbar support but side bolters were a little low OMP WRC - high side bolsters, generous space in the shoulder areas (but less shoulder support), and you really "sink" into the seat which helps offset the lack of shoulder support Recaro Pole Position - waist was in between OMP & Sparcos, shoulders felt crowded though All 3 seats were good and I wouldn't hesitate to run any of those brands, just have to pick what fits you best. I will say Sparcos are generally cheaper than Recaros so I think you get really good value with those. But if you're top heavy, I would look into OMP WRC XL's, really good leg support without crowding the chest/shoulders. One other piece of info, does the seat currently have harnesses? I'm assuming they don't because harnesses obviously require a harness or rollbar and the space is pretty cramped to begin with. Reason most folks DON'T go with aftermarket seats is because there's simply not enough room to install a rollbar. A harness bar may give you more space but isn't as safe and some clubs may not even allow them. So before you decide to commit to seats & harnesses, first check to see if you even have space to install a proper rollbar. I'm 5'9" and I barely have enough space for a rollbar and harnesses installed correctly (proper angle & spacing). And if it turns out you don't have enough space to run harnesses & rollbar, then you may want to look at something like the Sportser which will provide good lateral support but still compatible with the factory 3 points. Factory belt + CG lock + Recaro Sportster would do a good job of holding you in place. |
08-27-2014, 10:03 AM | #10 |
Rep 505
i barley squeeze sparco evo 2+ seats in my coupe. they rub against the door sills when closing the doors. other seat i was looking at were cobra suzuka pro's i believe. you can check seat dimensions based off the eve 2+ to get an idea of what will work fitment wise. let mentioned before you need to sit in seats and find what fits you also take into consideration where the opening for the harness are located in relation to your shoulders when sitting in the chair...too low is not good!
08-27-2014, 11:31 AM | #12 | |
Rep 60
09-03-2014, 02:20 AM | #14 |
Rep 60
Would something like this fit?
http://www.racing-seats-usa.com/20001.html I had a this seat in my 67 Camaro with no issues, but that was a much bigger car. |
09-03-2014, 08:23 AM | #15 |
Rep 505
These aren't fixed back seats, sadly I'm not familiar with options nor fitment, but using the measurements off one of the fixed seats mentioned should give you a ballpark idea on fitment.
09-03-2014, 09:45 AM | #16 | |
Rep 12,565
09-03-2014, 11:49 AM | #19 |
Rep 60
Yeah, I was hoping not to use a fixed back seat. I was hoping for ideas on a good sport seat that was not fixed back with a car that has a cage and had room for my rear end. I didn't think this was going to be as difficult as it has been. I would hate to lose the belts.
09-05-2014, 08:40 AM | #20 | |
Rep 2,176
09-05-2014, 09:28 AM | #21 | |
Rep 1,373
These two pictures are from when i first installed the seats. They are more reclined then I liked in these pics so I adjust them to be more up right which also gained be a bit of clearance.
07 Z4 M Coupe AW/IR |
09-05-2014, 10:21 AM | #22 | ||
Rep 2,176
