      06-04-2012, 06:14 AM   #1
CloudyLP640
Drives: RS
What spacer ??
Front wheels are 18x9 + 42 with a 245/40/18 tire.
Car has to be slammed on KW V3 coilovers.
Whats is the smallest spacers that will allow me to clear the coilover perch without poking too much in front.
Basically, I wanna run low, So I need the perfect compromise between clearing the perch and the fender...
No camber plates involved.
      06-04-2012, 09:34 AM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I think 12mm or 15mm. I'm running a 18x9 +40 with a wider, 265 tire and a 12mm spacer
      06-04-2012, 09:53 AM   #3
CloudyLP640
Drives: RS
do you think 8-10 would do the trick ? I wanna run as low as I possibly can on V3
      06-04-2012, 10:18 AM   #4
ZStig
279
I dont know... Bolt up the wheels to the car, and see how much room you got
