      03-25-2013, 03:38 PM   #1
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2009 Bmw 135I  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
help! some issues on my SI
an issue came up after I stored my car for 4 months, the car doesnt start up when I turned key to the position to start the car, nothing happen. not even "kekekeke" sound.
the engine will star after I turn the key all the way back and try to start again, . some time it takes me twice to start the car.
another issue persist from long time ago...its the clutch making rattle sound after a good distance driving ...(approx 50~100km)
no rattle sound when I press the clutch pedal all the way down but it comes back after I release the pedal (My SA told me its because the light fly wheel something)
I also feel the clutch is very solid while I just start driving, but feel it slips after the distance.
thanks for your help and input !!!
      03-25-2013, 03:57 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Assuming you had the car on a battery tender or have a new battery (that is, no issues with the battery) this sounds like an ignition switch problem. See this thread.
Clutch, could be a lot of things, from throwout bearing to worn friction surface, etc. But need more info.
How many miles on the clutch?
Slips while in gear and uphill with load? (And, if so, how do you know?)
Slippage only when car is hot?
Did the slippage start recently (is it related to the "rattle")?
Does the car shift smoothly or are gears harder to get in/out of?
      03-25-2013, 04:28 PM   #3
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
I currently have 53k km on the car, owned the car when 19k since then. dont think the clutch has been replace or something... not sure.
Im sorry that I use "slip" to describe the rattle. the rattle happened when I matching clutch at 1st gear. of course when car is driven for 50~100km, and it happened when the first day I bought the car.
sent the car to dealership when I noticed the clutch rattle two years ago, but they think its the N52 ticking problem and fix it,(all parts of cylinder head) (N52 ticking wasnt my concern at the time but still happy that they fixed it)
      03-29-2013, 09:24 AM   #4
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Sounds like a throw out bearing issue. I had the same problem on mine last year. At first I thought the knocking was the lifter ticking coming back. However, the knocking isn't there when you first start the car, but after you drive it, you can hear a knock that goes away when you push down the clutch. The dealer replaced the entire clutch assembly. The car was still under warranty.
      03-29-2013, 09:26 AM   #5
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
How'd you get them to change the cylinder head? My dealer only changed the lifters. If the lifter tick returns this spring, I'm going to request the cylinder head be changed too.
      03-29-2013, 05:49 PM   #6
3002 tii
3002 tii's Avatar
2288
Clutch chatter is normal on these cars. You hear it when clutch is out, silent when it's fully in.
Follow for latest mods
      04-13-2013, 12:31 PM   #7
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
I guess my SA John is a good guy? I got my car back after lifters be replaced then call back to complain the noise(clutch noise) right after I drove few KMs. John arranged another appointment for me to replace the cylinder head... after all... "the noise" still there... search quite a bit at the time, some said clutch bearing and some said the bmw clutch light fly wheel meant to be this way
