      04-03-2013, 07:04 PM   #1
mike519
mike519's Avatar
Drives: 2018 M240i
Roundel Sizes
Hi all,
I'm considering switching all badging over to monotone/carbon fiber on my M roadster and am curious about sizes for the roundels. As I measure them, I am getting the following diameters...just want to confirm before I order...
trunk roundel - 80mm
side light roundels - 80mm
hood roundel - 70mm (is this one special to the Z's? I thought I had read that they have a slight curve)
wheels - I have new anthracite EC7s that came with caps that seem to have 62mm badges...will get 62mm BMW CF roundels
steering wheel roundel - 45mm
For the 80mm and 70mm I measured, is this the correct size or is it 82mm and 72mm? These seem to be more common sizes.
Thx
      04-03-2013, 07:17 PM   #2
Drives: M2 Comp
The front is the odd one Mike @ 70 mm
You can get a 72mm to work though.
I installed the CF Roundels on my roadster.
The problem is that the bumper is curved ( pic )
, but with a little custom work on the Roundel & under it on the bumper, it will work.
This a 72 on my roadster, the highlighted areas is where the curve is a problem.
But when it's done it's nice & flush.
      04-03-2013, 08:28 PM   #3
mike519
mike519's Avatar
Drives: 2018 M240i
I thought I had read a post from you about that before, thanks Ian. If I go ahead, I'll drop you a line to figure out the front.
I have been reading about a set that has a proper fitting front emblem. Are the different between roadsters and coupes?
      04-03-2013, 09:03 PM   #4
Drives: M2 Comp
No difference, they're both the same..
