      08-16-2015, 08:59 PM   #67
3002 tii
3002 tii's Avatar
2282
Originally Posted by mpathic View Post
This thread is still relevant, though old.
Did the setup stay free of CE codes long term?
What's the pipe diameter into and out of the muffler?
Why not run a 3" pipe outlet instead of two separate pipes?
Any reason not to do this to an M? It certainly doesn't need two mufflers back there.
Asking because I just bought an MZ4 and want to drop the boat anchor exhaust before doing other tuning.
Not M owner but I did a single 3" stainless / mandrel exhaust after I installed headers. And to answer your question yes you really don't need the duals. Bimmerworld's race exhaust for the e46 M3 is a single sided exhaust, clearly more functional than aesthetics but it's not for everyone.
Headers merged to single 3"
Mandrel bent with small Flowmaster muffler in the back
Eventually switched from oval to dual tip
Start up
On track
Follow for latest mods
      09-05-2015, 07:39 PM   #68
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Start up
On track
What tips? Those look fantastic!
      09-05-2015, 09:11 PM   #69
3002 tii
3002 tii's Avatar
2282
After months of searching only place I could find it was eBay but I made sure to filter for made/sold in USA:
Stainless Steel Dual 3" Outlet/ Single 3" Inlet Slant Cut Exhaust Tip - Left
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
      07-27-2016, 09:30 AM   #70
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
I'm getting ready to do this mod- 07 3.0i with 3 stage manifold conversion.
I can't find a consensus on the correct muffler to use. The OP and video show a 12468 model, yet others are stating that the 12468 is too large and the 11385 is more suitable.
https://www.magnaflow.com/products?partNumber=12468
https://www.magnaflow.com/products?partNumber=11385
Can anyone else confirm which is the better fit, and if there is sound differences between the two?
      07-27-2016, 06:12 PM   #71
Steeler
Steeler's Avatar
2428
I used the 12468 on my custom 3.0 exhaust
It fit fine but I found it too loud
See my thread with clips
http://www.zpost.com/forums/showthread.php?t=972678
      08-11-2016, 08:42 AM   #72
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
Ok, my exhaust is done.
The 12468 is a 5x8 muffler and results in the muffler hanging down lower than the cross brace. I chose the 11385 Magnaflow and it fits relatively well. Its a 4x9 design.
I used two 3" tapered exhaust tips from ebay.
The custom cutting and welding to remove the secondary cats and stock muffler was done locally for $208.
03-05 Z4's use a resonator and don't have space for this muffler in the tunnel.
06-08 N52 Z4's have two secondary cats and have a larger tunnel that allow this muffler to fit, albeit relatively tight.
Link to muffler on amazon $94
The sound is absolutely incredible. Best exhaust note I've heard on a non-M bmw. Not too loud either on the highway, barely louder than stock.
Pics and videos coming later
      08-22-2016, 12:04 AM   #73
Asianoak
Asianoak's Avatar
Drives: '11 E92 M3 & "11 X3
2011 M3  [0.00]
Really appreciate your post and the fact you verified fitment of the two mufflers between the various years. I'm getting ready to do mine and have been curious about which muffler to use and that's the main reason I hadn't moved forward yet (local shops don't seem to stock either one).
Anyway, did you wind up removing secondary cats, resonator and the rear box? I'm trying to decide which route to go with mine prior to scheduling the appointment. Big difference though is that I've got a Z4M rear bumper and will be going with a dual exhaust set up so trying to figure out what set up will be best for street use with occasional track days.
Instagram: @dasianoak
      11-19-2016, 12:51 PM   #74
Forkast
Drives: 2003 BMW Z4 3.0i w/ sport pack
Question option for 03-05 exhaust mod?
This is the most helpful thread I've found on exhausts for our cars and while if you have a 05 or newer the magna flow muffler seems the way to go but for the earlier cars is there an option available that won't hang down and still fit one of magnaflow's mufflers? Otherwise i am thinking of making a manual exhaust cutout right before the last muffler with a hinge to open and close a bypass on one or both of the pipes. Any thoughts on this?
      11-28-2016, 12:00 PM   #75
JVDHM
JVDHM's Avatar
Drives: 3.0si Coupe
Did you end up getting any pics or vids or this? I'm curious as to how it fits
      11-28-2016, 12:12 PM   #76
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
https://goo.gl/photos/fqUQ4y9NnyKCNzWeA
Some light revving as the car wasn't fully warmed up. Definitely not too loud but makes it sound like a sports car should. No drone on the highway.
The only thing I'm not totally happy with is the placement of the exhaust tips- I think they are a bit far apart and I will probably take them back to get realigned.
      12-01-2016, 01:20 PM   #77
Taskmaster
Japan
2465
So if I understand correctly - no stock secondaries, no resonator and you put that magnaflow in place of the stock muffler?
Power increase? Sound?
      12-02-2016, 08:15 AM   #78
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
On the facelift version, there are two secondary cats in the center tunnel section, then the suitcase muffler in the back.
The mod is to cut out the secondaries and replace it with the magnaflow in the same place in the center tunnel.
Its a tight fit but the part number I listed works on mine and only has about .5" exposed from the bottom. Its louder and deeper but not to where it's annoying. Video is above. Power increase is negligible.
      01-21-2017, 08:04 PM   #79
tIndy
Drives: 2007 Z4 3.0i
So, on an 07 3.0i which do I use?
      01-21-2017, 08:32 PM   #80
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
On your car like mine you have the primary CATs in the exhaust manifolds, the secondary CATs, and a small resonator box before you get to the rather small muffler. I did the muffler delete and it yielded a sound similar to the videos in this thread and it was much less expensive to do. Had it for several months now and very happy with it.
Top Down 365
      01-21-2017, 08:55 PM   #81
deemo319
deemo319's Avatar
Drives: BMW
I really need to finish my exhaust.
      02-12-2017, 03:27 PM   #82
markp1958
Drives: 07 Z4 3.0i / 2014 740i
I want the set up of the OP it sounds perfect for me in the Video . I have an 07 3.0i so sounds like I need the 1385.The track video was super cool too! Thanks Guys for the interesting thread !
      06-14-2017, 02:26 PM   #83
jaywu415
Drives: 2006 BMW Z4 3.0i Blk/Blk
I'm sorry if I'm beating a dead horse. I was really inspired with this thread so I went ahead and did the same thing. This is to clarify any further questions other members may have as I was confused with all the other custom ways presented to us on this thread.
My car: 2006 BMW Z4 3.0i Roadster
Materials & Cost:
Magnaflow 11385: [$94.39 Amazon Prime] - Replaced the secondary cats
Magnaflow tips: 35122 (x2): [$103.52 - Summit Racing] - Replaced the Rear Muffler
Exhaust Shop labor fee [Oakland, CA]: [$120]
Total Spent: $317.91
Deleted: Secondary Cats and Rear Muffler. <-- Stored just in case CA smog test screws me over.
Sound: I'm absolutely in love. It sounds just like the OP's. My buddy had a 2004 330i SMG with Eisenmann exhaust - I honestly think its is relatively identical if not close in person. No drone IMO. Me and my girlfriend immediately noticed people staring us and "thumbs up" as we were cruising around town.
Butt Dyno: I don't really feel a difference. I'm gonna be honest, maybe it feels a bit more responsive? but that is probably my happy feet. =)
I will post a video when I get home. Thank you again OP for doing this thread.
scrammer421.50
ddakarr12.50
      06-16-2017, 09:13 AM   #84
DannysZ4
Drives: 2006 Z4 3.0I
I ended up going a less expensive route with mine. It may be on the slightly louder side with some drone at lower speeds. I am sure down the road when I want to start messing with it again I will do headers/secondary cat delete. Removed the rear box and had two small vibrant resonators installed and added Corsa tips.
      06-16-2017, 05:59 PM   #85
3002 tii
3002 tii's Avatar
2282
I like it, nice n simple. Be sure to upload some vids!
Btw hard to tell from that angle but make sure you have room between tips and bumper (right side looks awfully close). The exhaust bounces around and will expand as it heats up so you want to make sure there's enough room else you risk melting the cutout area.
      06-18-2017, 06:52 PM   #86
DannysZ4
I will eventually get some videos. It is pretty well mounted and has enough space on either side. It is just the picture that makes it looks close. Have about a inch of space on the top.
      06-22-2017, 04:19 AM   #87
tIndy
How much of a difference does the Magnaflow make in place of the secondary cats? I have done the muffler delete.
      07-22-2017, 06:01 PM   #88
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
Materials & Cost:
You get this video yet???
