      08-12-2014, 03:42 PM   #45
Alpina Roadster s
Drives: Alpina Roadster S LUX
Has any one done similar but introduced another couple of tailpipes on other side of rear bumper?
      11-18-2014, 01:09 AM   #46
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Can anyone provide any clarity on which muffler will fit best for this application? Anyone else done this?
      11-18-2014, 10:22 AM   #47
Incompatible
Drives: 07 AW Z4C 3.0Si
To date, there is not an ideal muffler for placement in the tunnel, or at least one which has been posted/listed here. Currently for the Si cars, the secondary cats must be removed and the magnaflow can identified earlier in this thread appears to sit lower which sacrifices ground clearance. Since this thread has been around for a few years, it's possible that there are other options for a tunnel mounted muffler which are now available. Stay tuned.
      11-18-2014, 03:05 PM   #48
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
What if you stagger 2 single mufflers like this?
      11-19-2014, 08:32 PM   #49
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
in for details on what fits...3.0 sounds fantastic with exhaust upgrade
      11-20-2014, 09:19 AM   #50
Incompatible
Maybe. Not enough room to stagger, but the 4" diameter might work. The #12468 Magnaflow can is a 5x8 oval and the 1" less hang down might be just right. Two of the 4" rounds won't dampen the sound as much as the larger internal volume of an oval can, but still might be acceptable.
      11-20-2014, 07:05 PM   #51
Exist
Drives: 2007 Z4 3.0si Coupe
Also in to see if anything fits better. $615 is still a really good price. I'd like to see if you could get lower.
-Spencer
      12-07-2014, 09:37 PM   #52
daysgoneby
Drives: miata
Thanks for the new ring tone
      03-11-2015, 07:49 PM   #53
DeutschRennfahrer
DeutschRennfahrer's Avatar
39
Drives: 2006 Z4 3.0i - Saphire Black
I just had this exact mod done on my 3.0i and it sounds fantastic! I was worried that it would be too loud, but it ended up being perfect. It's easy to keep it quiet when you want to, but it roars when you really juice it.
I went with a smaller Magnaflow dual muffler than the OP, and it fits great. I also went with a pair of Borla tips from Amazon.
Ended up spending a little over $500 after parts and labor.
      03-11-2015, 08:37 PM   #54
torchmedia
Drives: White Z4MC
^^ Great, have any videos of your car we can watch? Would be interested to see the different with your Magnaflow cans.
      03-11-2015, 09:05 PM   #55
DeutschRennfahrer
39
Yea I will try and put up some videos this weekend if the weather is nice.
Here's a picture of the install:
      04-29-2015, 09:18 PM   #56
DeutschRennfahrer
39
My apologies for the long delay in getting a video put together. Here's one I shot this evening. Enjoy!
scrammer421.50
      04-30-2015, 01:16 AM   #57
E86Z
Drives: 3.0si
sounds great, does it drone on the highway?
      04-30-2015, 08:26 AM   #58
DeutschRennfahrer
39
A little but not enough to be annoying. I like this setup because I can still keep it pretty quiet if I don't push it too hard.
      04-30-2015, 09:45 AM   #59
Incompatible
Link goes to muffler #11185 (no listing for this #), is this correct or did you mean 11385?
Any pics of the underside? Interested with how low the can sits, the OP install did hang down some. TIA
      04-30-2015, 09:55 AM   #60
DeutschRennfahrer
39
It fits great. It's a lot smaller than the OP's, so there isn't much overhang at all. I think #11385 is correct.
      04-30-2015, 12:35 PM   #61
Exist
So the 3.0si has a 2.25 in. piping?
-Spencer
      05-01-2015, 02:17 AM   #62
E86Z
Drives: 3.0si
It has two 2.25" pipes from pretty much front to back
DeutschRennfahrer, do you think it would've been possible to mount the magnaflow exhaust where the OEM can was?
      07-05-2015, 03:43 PM   #63
3002 tii
3002 tii's Avatar
2282
How has your rear bumper held up with these new tips? Any melting or discoloring?
Follow for latest mods
      07-05-2015, 06:03 PM   #64
DeutschRennfahrer
39
^^^Nope, none that I can see at least. Looks just like it always has.
      07-05-2015, 06:57 PM   #65
3002 tii
3002 tii's Avatar
2282
Thanks! When you have a moment, can you measure how wide your tips are from one end to another? A
I'm wondering if a set of dual 3" tips will fit (probably 1/2" space in between the tips) will fit nicely in the cutout without getting too close to the bumper itself.
      08-15-2015, 12:58 PM   #66
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
This thread is still relevant, though old.
Did the setup stay free of CE codes long term?
What's the pipe diameter into and out of the muffler?
Why not run a 3" pipe outlet instead of two separate pipes?
Any reason not to do this to an M? It certainly doesn't need two mufflers back there.
Asking because I just bought an MZ4 and want to drop the boat anchor exhaust before doing other tuning.
And you may ask yourself, "Where is that large automobile?"
