      09-28-2010, 04:54 PM   #1
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
High pitched whine after tranny fluid swap
I recently swapped out the tranny fluid and put in Royal Purple Synchromax. Since then, I've noticed a high pitch whine that's tied to the throttle coming from the tranny. I was concerned about a possible leak or lack of fluid, but the seals are good (new drain plug) and the left over fluid jives with the tranny capacity. No codes. Performance is fine, shifting is fine.
Should this be expected or should I turn it over to a pro for a look?
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      09-28-2010, 05:02 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Very strange, I experienced nothing like that at all.
      09-28-2010, 05:06 PM   #3
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Are you sure you put in the correct viscosity?
      09-28-2010, 09:09 PM   #4
a_riddler
Bimmer Noob
a_riddler's Avatar
O-cha,
I had assumed so, since there is only one version of the Synchromax. The Synchromax equates to the MTFLT1, and I saw that the Z4M's use MTFLT2. That is roughly a 75W85 SAE Grade, so yeah, maybe its the viscosity. I read favorable reviews of Synchromax in the Z4M, perhaps I should try the Max-Gear 75W90.
Here is the specs.
      09-28-2010, 09:26 PM   #5
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Um.... that looks like the viscosity of 30 weight oil....
      09-28-2010, 10:40 PM   #6
a_riddler
Bimmer Noob
a_riddler's Avatar
While I don't disagree, people have been using this in the Z4M successfully. I'd be willing to put in Red Line MT-90 to see if there is a difference.
      09-28-2010, 11:09 PM   #7
FerRrari
FerRrari's Avatar
19
Drives: Catrinel Menghia
I'd have someone else look at it. I experienced a whining noise on acceleration in 3rd gear in my MINI after a clutch replacement, didn't make much of it, long story short, total transmission failure occurred whithin a week.
      09-28-2010, 11:42 PM   #8
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Whine is bad for sure, any way you look at it. It's a sign of friction and/or collision.
      09-29-2010, 10:23 AM   #9
a_riddler
Bimmer Noob
a_riddler's Avatar
Didn't need much convincing, off to the shop. Thanks everyone!
      09-29-2010, 10:37 AM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
keep us posted.
      09-29-2010, 05:20 PM   #11
RBull
Drives: 2007 M Coupe
No issue here and I just swapped out a week ago. Let us know what happens.
      09-29-2010, 05:40 PM   #12
r4gs
Viper Driver
Singapore
36
Drives: F-16
hmm, interesting anomaly. i opted not to switch to rp synchromax even though i had two bottles shipped from amazon because i'd been intentionally working on my shifting technique. plus i'm only sitting pretty on 17500 miles.
      09-30-2010, 11:32 AM   #13
a_riddler
Bimmer Noob
a_riddler's Avatar
And the verdict is....
Power steering pump
It just happened after the fluid swap. Poor timing. I had noticed that the steering was rough, but attributed that to the increased negative camber from the TMS bolts.
Lesson learned. Only do one thing at a time when the car is up on the jack stands...
      09-30-2010, 12:09 PM   #14
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
Glad to hear it's not a tranny swap!
      09-30-2010, 12:40 PM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Sorry about your PS pump, but the rest is good news.
      10-01-2010, 12:11 AM   #16
Erhan
Erhan's Avatar
Drives: Cooper S
You should have left it as is since it is not the tranny It was sounding really good
