      04-30-2010, 07:47 PM   #1
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Autosolution SSK for Z4M
I talked to Ronald with Autosolutions today for about 30 minutes. He almost finish with the final design with a few details to work on. It will go in production around mid May.
Here are some preliminary details.
It will decrease the throw ~25%.
The shifter height will be same as stock.
The initial batch is 12 kits.
The kit inculdes selector rod.
The production run ends in August. He will decide if it is worthwhile to produce more kits.
Ronald will provide pics of parts as it go in production. I will post it here as I get them. The high cost is due to low production number. Please contact Autosolutions if you want to reserve one.
I am not affiliate with Autosolutions in any shape or form. Just like to share this with my fellow Z4M owners.
      04-30-2010, 08:20 PM   #2
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Is it going to be one of his zero clearance designs? I like the zero clearance but actually have no desire for a shorter throw (but I know hell customize the throw).
      05-01-2010, 06:02 PM   #3
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Would have been better if it reduced the shifter height as well. But either way it's too exapensive for a ssk.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      05-01-2010, 06:26 PM   #4
O-cha
O-cha's Avatar
218
Drives: Mcoupe
The only other ssk for our car is 300$ and is JUST a selector.
If the auto solutions one is like their others, selector, linkage and a carrier all zero clearances, then it should be worth it.
      05-01-2010, 07:07 PM   #5
JCz04Bimmer
JCz04Bimmer's Avatar
31
Drives: 06 Z4MC
Definitely interested.
My UUC Short Shifter is good but nothing amazing. It has this strange issue where when I'm in any of the forward gears other than 1st (so 3rd and 5th), the shifter doesn't pop out of gear, nothing close to that, but it goes in and then if I pull ever so slightly it clicks back about 1/4".
      05-01-2010, 09:28 PM   #6
F360C
Drives: E86 S54
Not totally true... Rogue makes one for our cars. Its only $150ish but yes it is only the selector also
07 Z4 M Coupe AW/IR
      05-01-2010, 09:51 PM   #7
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
my uuc is fine. it was a pain in the ass to install though.
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
      05-01-2010, 10:24 PM   #8
JCz04Bimmer
31
Drives: 06 Z4MC
It sure F&%$ing is.
      05-02-2010, 09:32 AM   #9
F360C
Drives: E86 S54
Originally Posted by JCz04Bimmer View Post
It sure F&%$ing is.
You guys had to take the whole exhaust off in order to remove the heat sheild just to get at that one stupid little clip too?
07 Z4 M Coupe AW/IR
      05-02-2010, 12:49 PM   #10
fatmatt0116
Hooligan
yes. Furthermore the instructions provided are for an m3, not a z4m. Initially when I called up UUC they insisted that it didnt need to be removed and then i finally talked to the owner who admitted that it does. In the meantime the hours added up. Irritating. Further, if you don't put the plastic washer on with the correct orientation then it results in a lot of play in the selector. I ultimately replaced the yellow plastic washer with 2 steel ones and now it is nice and tight. Lock tight is akey ingredient for fastening the cup to the selector.
      05-02-2010, 02:25 PM   #11
RobMCoupe
RobMCoupe's Avatar
60
I like the current height of the shifter with ZHP shift knob. I have Rogue SSK on 99 M3 and UUC on Z3 Coupe. They are OK but want to try AutoSolutions SSK because I hear this is the best SSK. I've been debating on which one to get for the longest. The last I checked, UUC do not have DSSR for Z4.
      05-02-2010, 09:01 PM   #12
MMMazing07
MMMazing07's Avatar
180
Drives: Z4M
yes. its called the "bitch clip"
      06-09-2010, 09:15 PM   #13
RobMCoupe
RobMCoupe's Avatar
60
Autosolutions Z4M SSK is ready
My kit is going to ship tomorrow. Here are some details and pics.
attached three pictures
installed height approx 13mm lower than stock
reduction ratio approx 15- 17 %
Note that it requires a modified shift bracket (supplied) and that the attachment to the bracket is by means of 4 hex bolts (also supplied) . Pivot ball was replaced with a teflon lined spherical bearing. selector rod connection at the lever was raised by 5mm
Shifter will be supplied with a hardened front coupler ( not shown)
Please contact Autosolutions for pricing.
First image is stock shifter
Second image is AS shifter
Third is stock and AS side-by-side
      07-18-2010, 10:31 AM   #14
RobMCoupe
RobMCoupe's Avatar
60
SSK Installed
I have my SSK installed. After driving a few days, I am very please with it. The throw is shorter than stock. You can actually shift from 3 > 4 with a flick of your fingers. It is very precise as well with no play.
      09-05-2010, 02:15 AM   #15
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Sorry to bring back an old thread, but how much did you get your AS SSK for? I have been trying to contact AS regarding the Z4M SSK to no avail
Are you the only one with this installed in the Z4M? I see you're in the bay area, could we possibly meet up so I can check out the AS SSK?
      09-06-2010, 09:59 AM   #16
RobMCoupe
RobMCoupe's Avatar
60
I PM you Autosolutions contact number and meet.
It cost me $350.00 for SSK plus $15.00 shipping.
      09-07-2010, 05:46 AM   #17
mfanatic325
///M-fanatic
Taiwan
193
Checked this out in person today. I'm sold. Thanks for ur time Rob!
      09-10-2010, 08:47 PM   #18
mfanatic325
///M-fanatic
Taiwan
193
The heck...the guy wants like $399+
How'd you get the $350 pricing Rob? lol
Also, he claimed that he would have to produce some, resulting in a lead time of a couple weeks before he can even ship it out to me.
I thought he made a small batch originally? Seems kind of shady no?
Unless there were like quite a few other buyers of these already that we don't know of?
      09-13-2010, 11:46 PM   #19
RobMCoupe
RobMCoupe's Avatar
60
Ronald with Autosolutions is a nice guy. He probably discounted me for such a long wait. I waited almost 8 months to finally have one made. Ronald said he usually make a batch run of a dozen or so. It wouldn't make business sense to make one of to sell. Remember they can customize the throw and shifter height for you. Be patient.
      09-14-2010, 12:07 AM   #20
mfanatic325
///M-fanatic
Taiwan
193
Yeah I guess what kinda bothers or irks me is the fact that I had expected some to still be in stock from the original run. But that doesn't seem like the case. Unless he's truly trying to make an extra $50 or so.
      09-18-2010, 01:32 PM   #21
RobMCoupe
RobMCoupe's Avatar
60
I contacted Autosolutions if they will consider a group buy. I am proposing 5% for 5, 10% for 10, and 15% for 15. Autosolution have not return my request yet, but like to know how many are interested.
      09-18-2010, 01:35 PM   #22
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
I'm.
