03-22-2010, 01:56 AM | #1 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
NA vs. Supercharger vs. Turbo
Now having driven both Normally Aspirated cars and Turbocharged cars, I am interested in those owning Supercharged Z4M's and your opinion of driving these cars on a road circuit. My 335d, while modestly powerful, has an annoying amount of turbo lag which I can imagine would be difficult to modulate when driven aggressively out of corners on a road circuit.
My main question is whether SC cars exhibit the same type of lag in the power development and whether or not those of you who own a SC Z4M have any regrets about leaving the NA engine behind. Some days I am torn about whether I should go SC or build a race engine and leave it NA knowing I will lose some top end power.
You have to be 100% behind someone before you can stab them in the back.
David Brent |
03-22-2010, 04:59 PM | #2 |
Rep 1,090
Considering the s/c used on the M are centrifugal, power delivery is exactly like NA just much stronger.
It will be very linear as boost builds in relation to rpm, so the only difference between NA and S/C is that the S/C M should keep making power all the way to red line and not tapper off like stock does. Throttle response should be no different. Turbos you think might be harder to drive but obviously once your racing you dont drop the revs enough to drop out of boost. So turbo lag isnt a problem. Plus you can get more boost/full boost sooner with a turbo so your mid range will be stronger compared to a centrifugal s/c set up. People have their preferences and thats fine. My last car had a Rotrex s/c set up and i loved the power delivery - revving to 8500rpm it felt just like a crazy NA set up. My friend had the same car as me but went with a turbo set up. His you could defiantly feel the power swelling then explodes once full boost hit.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
03-22-2010, 11:51 PM | #3 | |
Rep 4,726
03-23-2010, 04:37 PM | #5 |
Rep 1,090
^ no turbo kits for the M, mainly because not many people can tune the ecu as needed.
135i N54 manual
03-29-2010, 08:08 PM | #6 |
Rep 80
I'm sure you can use HPF's turbo kit for the E46 M3 but the intercooler piping will have to be customized to fit the E85/E86 chassie. If you dont want to deal with the intercooler pipes you can always go for a liquid to air aftercooler. HPF is using an AEM stand alone acting as piggyback, so almost any good local tuner can tune it.
03-29-2010, 08:11 PM | #7 | |
Rep 4,726
Trust me.
03-30-2010, 12:23 AM | #9 |
Rep 4,726
Proprietary AEM hardware. Completely different ecu and wiring harnesses between the cars, I noted a few possible clearance issues with the manifold vs tranny (wastegate pipes is very close to m3, z4 has protrusions there)
Fuel system would also have to be redone for higher stages as our FPR is in the tank.
