      04-04-2011, 03:39 PM   #67
Amylovebus
Amylovebus's Avatar
Drives: 2005 BMW Z4 3.0 Alpine White
Originally Posted by kav View Post
I have no idea how you managed to do this..
I used the same hair dryer technique but was left with the residue.. I tried Goo-gone (all they had), then nail polish remover, then bug/tar remover, then stain remover and the residue is still there!! It looks bad. Is it worth trying goo-off, if I can find it or using a laquer thinner (I thought the nail polish remover would be the same)?
Do you think WD-40 or Pam cooking spray might work?? It's worth a try...
and neither should hurt the color of the visor.
Thanks,
Amy
      04-10-2011, 02:27 AM   #68
robrwalker
M addicted
robrwalker's Avatar
Drives: 2017 YMB F82, 2018 AW F86
Use Goof Off
Just went to local hardware store bought $8 can of goof off
Sprayed it on the visors (out of car) gave it a rub, sprayed and rubbed 2x more - now my visors are clean and relieved of that useless warning.
Goof off is great stuff. Worked perfectly.
      04-10-2011, 10:28 AM   #69
HOG4DNR
HOG4DNR's Avatar
Drives: 2014 M235i
^ Can not go wrong with Goof Off. I have leather visors and it worked like a charm (much easier if removed). I just used leather conditioner on them when I was finished.
2008 Z4MC #1786/1815 "The Last IB w/ Extended Leather Made" Gone but Not Forgotten
2014 M235i E.Blue Mods in Progress
      04-11-2011, 12:18 PM   #70
jdl1pt
Drives: Z4M coupe 2007 IL Blue
Those of you doing this mod/removal now, any discoloration due to sun fade?
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
      04-13-2011, 08:32 PM   #71
robrwalker
M addicted
robrwalker's Avatar
Nope. I do not think the visor gets much sun. At least I didnt have any problems on an 07 coupe.
      04-14-2011, 01:37 AM   #72
jdl1pt
Sweet, will do this soon.
Thanks!
      04-18-2011, 06:54 PM   #73
Amylovebus
Amylovebus's Avatar
I used the goof-off on mine. Afterwards I cleaned with alcohol and then conditioned with leather cleaner. It was easy and looks great!!
Thanks for a great idea!
Thanks,
Amy
      04-22-2011, 07:09 PM   #74
Amylovebus
Amylovebus's Avatar
Here are the results of my label removal.
Name:  visor - before.jpg
Name:  visor - after.jpg
Name:  visor - reinstalled.jpg
Thanks,
Amy
      04-23-2011, 01:11 AM   #75
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Gotta find time to do this mod! Looks good Amy!
      04-24-2011, 04:16 PM   #76
ZedFourM
Drives: Z4MC - Interlagos
Thanks for this trick....will give it a try.
Originally Posted by Dammmittt View Post
I tried doing it with Goo-gone and I didn't feel like wasting more than 2 minutes on it at the time. Perhaps goof-off is stronger...
Yeah, Goof-Off is Xylene, which is a pretty strong organic solvent. Goo-gone is a very complex oil (complex oils can sort of dissolve simpler oils), so they work differently. I would be a little concerned with using it (baselessly -- would have to know more about the vinyl).
      04-24-2011, 10:13 PM   #77
jdl1pt
Thanks for posting the pics Amy.
      05-06-2011, 08:48 AM   #78
Kimo
Drives: E31 E90 F25 MCS
For those that might resurrect this thread during a future search, here are a few more thoughts on the process:
Car is an '08 Z4 3.0si with the vinyl covered visors. Black.
These visors are so rigid that they almost appear to be a single 'slab' of molded plastic, but they are indeed covered in a very tightly stretched vinyl.
I purchased the can of liquid (not spray) Goof Off Professional (MUST be Professional) from the paint section of Lowes (5 or 6 bucks).
Remove the visors!! There are only two Phillips head screws per visor. It is much easier -- and SAFER -- to do this on your workbench.
Wear rubber gloves.
Stick two fingers in an old terry cloth rag, soak up a decent amount of the Goof Off Professional, and start rubbing over the decal in a circular motion. Within seconds, the decal will begin to disintegrate and can be wiped off, then another application or two to completely remove any residue. Once the decal is completely gone, go over the entire exposed surface of the visor with another application of Goof Off Professional to feather out and clean the entire surface.
Thoroughly clean the surface with a water soaked rag and then a cleaner, i.e. Simple Green, etc.
I had very few ripples, but (as described in earlier posts) they tightened up as the material dried.
Once dry, I could still make out some lines and inconsistencies, and considered going back over the entire side with another application of Goof Off, but instead decided to try a tip that appears earlier in his thread, i.e. Forever Black. www.foreverblack.com
I've used this product (sparingly) for years, and actually still have the original bottle that I bought YEARS ago. The box says "New", so I must have bought it when it first came out.
This stuff goes on like black liquid shoe polish (sponge tip applicator), and I covered the entire surface with a generous amount, smoothing any puddles, etc. until I had a nice even covering.
Once dry, the visors looked perfect!!
      08-28-2013, 07:21 PM   #79
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Attachment 514215
Someone else mentioned that the fabric will tighten up once it dried. I just wanted to confirm. The picture above looks like the material got really saggy/loose. Did that go away once dry?
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R|
      08-28-2013, 09:37 PM   #80
wolfman1807
Clueless
wolfman1807's Avatar
Drives: 2003 Z4 3.0i SMG sport/premium
Mine looked like that if not worse when I did mine, but after a few days of worrying it looked good as new. Minus the decals of course!!!
      08-28-2013, 10:02 PM   #81
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Cool, that gives me more confidence. Thanks wolf.
      08-28-2013, 10:13 PM   #82
wolfman1807
Clueless
No problem, I sweat the little things too!!!
      08-29-2013, 12:27 AM   #83
StickMon
StickMon's Avatar
Drives: 2006 MR
I did this on my leather visors a few weeks ago.
First one:
Dumped lots of Goof Off Professional liquid on the label. Melts it immediately.
Trouble is the Goof Off evaporates in about 10 seconds, so you have to work fast to mop off the label.
I was left with a slightly sticky residue, and you could still see a ghostly shadow of WARNING.
So I put on more Goof Off and rubbed some more. Making progress.
Lots more Goof Off, rubbing harder ... making progress ... almost got it ... ohshit ... rubbed top layer off the leather.
Quit while I was behind. After re-moistening the leather with lots of Glovolium, and then Meguiars, and finally Gliptone, got it mostly back to goodness.
Second one:
Dumped lots of Goof Off on the label and mopped gently until all the white and yellow was off.
Quit.
Summary: Quit while you're ahead and don't worry about the ghost WARNING.
As others have mentioned, part of my problem was that mine were baked on by years of California sunshine.
      08-29-2013, 05:06 AM   #84
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
FWIW
These labels get a little more difficult to deal with now that the cars are a little older.
In the OP, I did that with my M roadster when new & it was VERY easy.
I picked up my coupe used & noticed that it was more difficult to do.
      08-29-2013, 05:32 AM   #85
GP20
My M was built in Nov., '07, and I removed the stickers in Oct, 2010, using Goo-off and also magic eraser. Absolutely zero residue or shadow. The visors looked completely fucked up while I was working on them and I was certain that I had to buy replacements. But after I cleaned and dried them and put a couple coats of leather conditioner on them, they looked brand new.
Disclaimer: use magic eraser / goo-off at your own risk.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      08-29-2013, 08:31 AM   #86
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
During the application, it looks like a mess but have faith and they will go back to looking normal once everything is dried!!!
The Raspinator
      08-29-2013, 09:22 AM   #87
itdnwiwbp
Drives: 330iZHP
I used Goof Off and an old tooth brush. I found that covering the area then brushing lightly from the edge inward removed it almost in once piece with no residue. The one that I "scrubbed" left a little bit of residue. So don't scrub, lightly brush from an edge in one direction without rubbing the decal. Basically don't set the bristles directly on top of the decal.
      08-29-2013, 10:32 AM   #88
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
When you guys "apply" the goof off, are you basically just pouring it directly on top of the sticker, creating a small puddle? Or applying to a rag first? Or something else?
