01-05-2013, 03:21 AM | #1 |
Rep 5,329
ESS VT2-575!!!
01-05-2013, 01:13 PM | #5 | |
Rep 5,329
I agree tho, think we're taking this too far on stock internals. I feel comfortable at 8lbs, ill work with catless, cams, meth, and evolve custom tune and leave it Thier until I build the motor.
01-06-2013, 03:08 AM | #7 | |
Rep 5,329
Maybe with this kit they will look at supplying a proper fuel upgrade. Then again looking over the system, it's easy to done without a tuners help.
01-06-2013, 07:32 PM | #8 |
Rep 112
What would we need? Better fuel pump? More volume?
01-07-2013, 12:02 AM | #9 |
Rep 33
M3 E46 also has problems with the fuel pump.
In this kit is a clear need to upgrade the fuel pump. http://store.activeautowerke.com/act...vel-2-p44.aspx With the kit CFR525 cold weather i carburation problems. |
01-07-2013, 12:09 AM | #10 |
Rep 33
A friend mechanic has tested on the engine test bench S54 engine designed to drift with Vortech V3 Si, Motec M600, decompressed pistons (8,5:1), connecting rods reinforced, camshafts schrick 288/280, 13 psi, 110 octane race fuel .
Result reliability: 650 hp motor at 8000 rev / min. They bought the kit VT1 450 to use the compressor bracket and Intake Manifold. Obviously the injectors of the kit were small and were replaced. As used two fuel pumps Walbro 255 and pressure regulator on the return. It goes without saying fuel rail modified. To maintain its reliability, have been content. They had achieved more than 700 hp at 17 psi. my mechanic friend is Gozzoli (http://www.gozzoli.it). Don't get me wrong, I don't want to advertise. Only information. Last edited by pandusr; 01-07-2013 at 12:30 AM.. |
01-07-2013, 02:25 AM | #11 | |
Rep 5,329
01-07-2013, 02:27 AM | #12 |
Rep 5,329
fuel pump, injectors-660cc, FPR, mayber large lines.... that would do nicely...
The aeromotive 340lph intank can support 650whp easily... so that would be my choice.
01-07-2013, 08:22 AM | #13 | |
instagram 997turbotom
279
Rep 7,377
01-08-2013, 07:11 PM | #15 |
#dubspec
6339
Rep 5,201
Get a veryron fuel pump. The Audi guys have been using them and solved the problem
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
01-08-2013, 07:19 PM | #16 | |
279
Rep 7,377
01-08-2013, 07:27 PM | #17 |
#dubspec
6339
Rep 5,201
