02-27-2012, 01:02 AM | #1 |
Rep 1,663
Gear ratio 3.62 vs 3.91
For an NA car, in your opinion what gear ratio is best: stick with stock, go to 3.91 or even 4.10?
02-27-2012, 06:54 AM | #2 |
First Class M
20
Rep 217
Drives: Z4M Coupe, E36 Coupe
I say go for a 4.10 becoz it's a huge, difference and a gain of a power feel. thinking of it but it really cost a lot to get a 4.10 or 3.91
'07 Z4MC l Alpine White l Supersprint Race Exhaust l Supersprint X Pipe l OEM Carbon fiber Spoiler l H&R Springs l Vossen VF051 l G-Power SK I 415 rwhp l RPI Scoop l ///M Performance Knop. |
02-27-2012, 07:08 AM | #3 |
Rep 2,138
Drives: Me
This is an open ended question with no right answer.
What do you want to do? What are your expectations? How far do you want to go? How much do you want to spend? |
Grumpy Old Man6483.50 |
02-27-2012, 08:49 AM | #4 |
Rep 1,224
What's the car going to be used primarily for? Other mods?
02-27-2012, 01:38 PM | #5 |
Rep 1,663
I wanted it to be an open ended question to open it up for discussion, see what people think about the stock diff ratio, or changing diff ratios in general. If I had to specify usage I'd say mostly street with a few track/autocross events a year.
02-27-2012, 03:35 PM | #6 |
instagram 997turbotom
284
Rep 7,377
There used to be an excellent thread comparing these ratios, including theoretical acceleration numbers. I can't find it
02-27-2012, 03:55 PM | #7 |
Rep 2,138
Drives: Me
There are several threads on this subject. Some started back in 2006.
Starscream had a very good one going if I remember. |
02-27-2012, 05:06 PM | #8 |
Rep 1,663
I think you mean this post and this post.
I've seen those and was more interested in seeing if people felt that the stock gear ratio was best and why, or informed opinions from those that have changed ratios or have driven cars with different ratios.
02-27-2012, 05:09 PM | #9 | |
Rep 2,128
Personally, I've no plans for FI and I went with the 3.91, but the modification plan for my Coupe was specific: I wanted to build the car I felt the M Division should have built, using OEM parts (3.91 final drive, Aero skirts, CSL wheels and PS2s ala M3). My working theory at the time was that they wouldn't have used the 4.10 in a production car as it requires a shift to 3rd for the 0-60 dash, so the time with it is actually slower than the stock 3.62. Imo, it's perfect for a street-driven M Coupe, but many people with S54-engined cars (E46 M3s, Z4Ms) feel it's too mild an upgrade for the money, especially since the swap to a 4.10 is the same price. I did a couple of lengthy posts on the change at www.m3forum.net, in the M Coupe section. |
02-27-2012, 07:49 PM | #10 |
Rep 932
My original plan is doing 3.91 ring and pinion. I am considering 4.10 for bang for the buck. That is the reason it is still on my list of mod. Keep going back and forth on this.
02-28-2012, 03:11 AM | #11 |
Rep 428
I would see an added benefit of going with the 4.10 AND a supercharger...maybe not a turbo, then I'd keep the stock LSD ratio.
1999 /// M3 Convertible Techno Violet |
02-28-2012, 05:41 AM | #12 | |
Rep 1,739
Drives: 2008 Z4MC
02-28-2012, 05:59 AM | #13 |
Rep 2,120
I dunno why people always say that about 4.10's,
I have 4.10's and the car is no more skiddish than what it was with the stock diff, I can also launch the car in 2nd gear but for just driving around 1st gear is still 100% useable, TBH I've got so used to 4.10's now I don't even feel them lol, I want to drive a stock Z4M again to see the difference
Imola Red Roadster |
02-28-2012, 01:44 PM | #14 | |
Rep 2,128
I don't think anyone disputes that the 4.10s are livable with the stock S54. |
02-29-2012, 04:34 PM | #15 |
Rep 1,663
I'm surprised no one has made a case for keeping the stock ratio. Anyone else have 3.91 or 4.11 gearing and want to give their opinion?
02-29-2012, 07:55 PM | #16 |
///M-fanatic
193
Rep 3,885
I went with 3.91s because I have plans for FI in the future
They're nice You'll be spending around $1k just for the differential rebuild though, just FYI. And that's excluding the cost of a ring & pinion set. |
03-31-2012, 06:28 PM | #17 |
Rep 704
Drives: '08 MC
This is the best summation i've read that accurately describes the way I'd consider modding mine, and with the same reasoning behind it. The gearing makes a lot of sense, and yes its a tough decision. If only we had 1 of each lined up in a row so we could test them back to back in some parking lot.
03-31-2012, 06:48 PM | #18 |
Rep 704
Drives: '08 MC
do you really need to be skipping 2nd gear with a 4.10? and it really is slower than stock 0-60 as a result? Interesting.
03-31-2012, 07:46 PM | #19 |
Rep 1,663
It's not skipping the gear, it's that with 4.10 gears you top out at 50 something mph in 2nd gear. So you have to shift to 3rd to go over 60mph. So 0-60 you'll be slightly slower (since you have to do one more gear change) but 0-100 you'll be faster.
03-31-2012, 08:34 PM | #20 |
Rep 2,782
0-60 times don't tell the whole story. It's about distance traveled over time. In an extreme case (to prove my point) let's take two cars with identical 0-60 times of say 10 sec.
1. Car #1 jumps to 10 mph in the first sec and remains there until the last second, where it reaches 60 mph. 2. Car #2 jumps to 50 mph in the first sec and remains there until the last second, where it reaches 60 mph. Car #2 will appear to be much faster because it has covered far more ground, even though 0-60 times are identical. Without traction issues, a car with a 4.10 final drive will beat a car with a 3.62 in all but the very shortest of straight-line races. The real issue is having to switch gears mid-corner.
03-31-2012, 09:38 PM | #21 | |
Rep 704
Drives: '08 MC
OK, makes sense very helpful. stupid question here... in the example above, which car would have the 4.10 and which car would have the stock 3.62? I would assume car 2 has the 4.10? And switching gears mid corner is probably something i'd be more concerned about on a track rather than on back twisty roads? trying to feel out what gear makes the most sense for the way I use the car....
03-31-2012, 10:38 PM | #22 | |
Rep 2,128
My other "Z4M done right" plan was to order an M Roadster with manual top and seats, swap in the 4.10 gears and chip it to raise the red line until I could still hit 60 in 2nd, and start shaving weight to make it a Speedster but still livable - lightweight exhaust, lighter ac compressor and alternator, lighter battery, lightweight pullies, lightest wheels I could find (I think I had Volks in mind), race buckets... The target was 3000lbs, iirc. It would have been TiAg with black interior. Ah well... |
