      04-18-2024, 12:26 AM   #1
Henkan
Henkan's Avatar
Sweden
11
Drives: BMW X3 E83, 650 F12, X3 G01
Remove antenna base
Does anybody have instructions on how to remove 2 and 3? I need to replace my antenna, but it is stuck onto the base and cannot be unscrewed, hence I need to remove the base.
2007 BMW X3 2.0i E83
2012 BMW 650i Convertible F12
2023 BMW X3 Xdrive 30e G01
Gone: 2002 BMW 330i Convertible E46
2020 BMW X3 Xdrive 30e G01
      04-18-2024, 06:25 AM   #2
JCF
Drives: 07 Z4 M Coupe
You have to go in through the trunk.
https://www.pelicanparts.com/techart...eplacement.htm
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
      04-18-2024, 07:21 AM   #3
Henkan
Henkan's Avatar
Sweden
11
I have tried this but the problem is that the base is stuck and cannot be removed, even though the amp has been unscrewed…
      04-18-2024, 08:41 AM   #4
Henkan
Henkan's Avatar
Sweden
11
Fixed it, found the exact way to align the base to match the hole to enable it to be loosened.
      04-18-2024, 07:49 PM   #5
Aloyouis2
Drives: E85 (not E86)
Thanks for the Pelican DIY. Now I know I will NOT be replacing my antenna with a stubby. LOL.
      04-18-2024, 11:27 PM   #6
Clearancediver
Drives: 2004 Z4
Screw out long antenna and screw in stubby… max 1 minute to do. Thats how long it took me on my ‘04.
Sent from my smart phone...
XMetal1145.00
      04-19-2024, 05:45 AM   #7
Henkan
Henkan's Avatar
Sweden
11
1 min, provided the antenna CAN be unscrewed from the base. Which it cannot in 9/10 cases due to corrosion in the threads.
      04-19-2024, 10:51 AM   #8
Aloyouis2
I will have to see how stuck it may be. Did you notice any drop off in reception when you replaced with stubby?
      04-19-2024, 11:35 AM   #9
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
I hadn't noticed any reception loss with my BMW OE stubby. Your mileage may vary with the aftermarket stubby.
      04-19-2024, 04:21 PM   #10
Aloyouis2
There is a BMW OE stubby? Did not know! Do you have a part number or a way to identify?
      04-19-2024, 06:06 PM   #11
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
https://www.fcpeuro.com/products/bmw...na-65202296761
