02-22-2021, 03:34 AM | #595 |
Rep 133
Great Progress Vanne. engine sounds good. Cant wait to see end result. I see the SAP is removed on your car, assumed the smoke from heat wrap was coming from SAP port on the cyl head until i saw your comment on the exhaust wrap, did you guys code out SAP as yet?
Josh is a legend, thank you for the referral. We are going to start Servern tuning my Z4m this week.
02-22-2021, 06:22 AM | #596 |
Rep 484
Josh also sorted out my ecu after Epic locked it. Randy is so paranoid of someone stealing his tune that it leaves one in a bind if you want to switch to a tuner that will actually work with you and be responsive.
Are you planning to dyno tune this beast? |
Vanne1623.50 |
02-22-2021, 10:15 AM | #597 |
1624
Rep 4,296
Not sure yet Micheal, just depends if we have time left over before it get really warm here.
There's one shit thing.. due to the huge air to air heat exchanger, there isn't anywhere for the brake coolers hoses to go... I'll have to have a new look when it's all together.. hopefully get time on the lift tomorrow.. front end semi setup and have to replace the tie ends with E90 parts.ill document as I go along tomorrow. Will also run the diff on the lift tomorrow, prob for 15 mins while we data log for Josh. Need the welders to come back and weld in the supports for the dash and fix the pax foot stand mount. Need them to weld up the rear bumper supports and the front quarter guards supports.. I haven't really looked at how the headlights are gonna go... I have a distinct suspicion that were going to be able to use the lens..a d that's it.. stay tuned...
Powered by |
02-22-2021, 03:17 PM | #599 | |
Rep 11,668
when I had an ECU issue & car not starting, he had me ship the ECU down to him to sort it out. Got it back and still didn't work. Went through hell to get it sorted elsewhere. I wish I had know about Josh at the time. |
Vanne1623.50 |
02-22-2021, 07:37 PM | #601 | |
1624
Rep 4,296
Seems like an eons ago.. lolol.. Lol its actually complete horseshit.. I estimated the car to be off the road/track for 6 months total while the change/rebuild was going on.. (and that was dubbled up from the estimated 3 months work required) pffttt.... lol Its been longer than a year already... lets just say its a journey.... hahahaha
Powered by |
02-23-2021, 04:04 AM | #602 | |
Rep 133
Okay great news regarding the SAP delete and Blank off. I plan to do it as well and saw that the e85 2.5L and 3.0L models dont have the SAP, they come with a Blank off plate on the CYL head so was considering getting that blank off plate from BMW and fitting it when i remove the PUMP out the car.
Vanne1623.50 |
02-23-2021, 06:32 AM | #603 |
Rep 484
You may not need brake cooling. I have 355 mm rotors and find that brake performance improved when I removed the cooling ducts. Brakes weren’t getting hot enough. YMMV...but give it a try.
Make CF blanks from the headlights. Easy to do. Add about 5mm of clay to two sides so it fills in the gap better. |
Vanne1623.50 |
02-23-2021, 05:33 PM | #605 |
1624
Rep 4,296
Thanks. Yeah sounds pretty good I thought too.
Thanks Micheal, I'll have a look about the brake coolers. I did notice due to the bigger spacer that there is now much more room for the brakes to breathe a little. Quick comparison of the OEM Z4M inner tie rod and the now installed E90 inner tie rod. There is about an inch and a half of difference each side. Which comes out about right as the hub is now 55mm further outwards than OEM.
Powered by |
02-25-2021, 08:30 AM | #606 |
1624
Rep 4,296
ALU uprights in first stage of production..lol you'll notice these are a tad longer. Just need to get the insides machined out and painted up. Couple of shots of the arms kit.
Powered by |
02-25-2021, 06:35 PM | #607 |
Rep 3,004
Oooooooohhhhhhhh....
Heim joints with Nylock nylon-locking nuts....this is GOOD! I do have a very harsh criticism regarding your F1 build....it appears you could have saved a zillionth of a gram on the side mirror fastener bolts....they should have been made out of space-age titanium (or knowing how you're approaching this build) you already saved the zillionth of a gram!
Racerbruce
Vanne1623.50 |
02-25-2021, 09:04 PM | #608 |
1624
Rep 4,296
Lolol.. just to set you at ease then, I had to drill out 1mm at 12mm circumference for the mirror mount to slot in over the 6mm insert. That should be about a zillionth of a gram.
Powered by |
racerbruce3854.50 |
02-25-2021, 09:10 PM | #609 |
1624
Rep 4,296
Spent yesterday prepping up the 2 front CF guard mounts. Nifty little pieces actually. Might take a pic of it today. I also have to fix a few holes that need to be filed in and have to cut a few bits and pieces from the arches.
Fun fun...
Powered by |
03-03-2021, 06:42 AM | #610 |
1624
Rep 4,296
Pretty sure i said a few bits and pieces...
lolol... Before... After... well half way really... So thats given me an extra 2cm of suspension travel. Originally when the car is standing on the floor there is only 1.5cm or clearance with the rubber and the arch (thats static, not even at speed) Have to seam weld it back together tomorrow.. then the other side... and this will give me the opportunity to run real slicks with a proper side wall when these run ins are done for. Not sure if its evident in the picture, but ive just continued the radius of the arc all the way around. not really sure why they didnt do that as OEM?.. anyways, bit of a mess now, but i think it will clean up really nice.
Powered by |
wdb4754.00 |
03-03-2021, 10:02 AM | #611 | |
Rep 3,004
Bloody Hell!!!!
Sounds a lot like my wife's Subaru Outback....ONLY DIFFERENT!!!! SO incredibly awesome - can you even imagine what it will be like to strap The Beast on....cinch down your racing harness and....go WFO
Racerbruce
Vanne1623.50 |
03-04-2021, 07:18 AM | #612 | |
Rep 1,373
07 Z4 M Coupe AW/IR |
Vanne1623.50 |
03-05-2021, 10:03 PM | #613 |
1624
Rep 4,296
Thanks, not sure my wife would agree with you
Couple of bits and piece arrived from LA. Thx Alex. (you'll notice the DSSR... yeah that's my second one, though this one is nicer, as my previous custom one was nicked on one of the services done at a previous workshop. This happens a lot in these parts of the world... apparently.. i was absolutely fuming ) This one is much better built though and definitively an upgrade from the previous one and I also ordered a few bits and peices from Amazon last night to build the cable for the steering wheel push buttons, to control the Racepack on the fly.
Powered by Last edited by Vanne; 03-05-2021 at 10:09 PM.. |
wdb4754.00 |
03-15-2021, 02:59 PM | #614 |
1624
Rep 4,296
Added another bit. Snow Performance 210 Stage 2 Boost Cooler Water Methanol Injection Kit. Not for extra HP, but to up the Octane rating of our crappy fuel over here.
Powered by |
03-16-2021, 06:56 AM | #615 |
Rep 1,373
I would have thought you got the good fuel over there?
03-17-2021, 12:23 PM | #616 |
1624
Rep 4,296
nope, the fuel is absolutely dirty here... and race fuel is crazy expensive here. This is cheap insurance that the engine doesnt go bang.
Powered by |
