      11-25-2013, 03:50 PM   #1
masz4m
Drives: 07 Z4MR
non-lowering springs for Z4MR?
Need to replace shocks, going with Bilstein HDs. Was thinking of replacing the springs as well but don't want to lower the car, maybe just a 1/2 inch but no more. So, what are my options? Should I just keep the OEM springs, I didn't mind them that much except for the lift on acceleration. Do springs go bad, i.e. should I even consider replacing them with OEMs?
Car is DD.
Thanks!
      12-05-2013, 07:15 PM   #2
masz4m
Drives: 07 Z4MR
Anyone? I'm still searching but no luck so far....
      12-05-2013, 07:47 PM   #3
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6328
Eibach springs only lower 0.5"-0.75.
instagram: @ dubsesd
      12-06-2013, 10:57 AM   #4
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
Car is DD.
Thanks!
I just put these shocks on my car with OEM springs and could not be ha ppier. PM ME if you have any questions.
Daily: 2010 Tacoma Double Cab
      12-06-2013, 11:13 AM   #5
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
Car is DD.
Thanks!
Keep OEM, the dive is from lack of compression dampening in OEM shocks.
      12-07-2013, 08:35 AM   #6
masz4m
Drives: 07 Z4MR
Thanks, I could live with a 0.5 drop all around, but seems weird to have the rear 0.25 lower than the front - which is what these springs do, right? I'd think it makese sense to have the front lower than rear....
Anway, I'll keep this on my list for now....
Thanks again!
      12-07-2013, 08:37 AM   #7
masz4m
Drives: 07 Z4MR
Thanks! I'll PM you right away with some more questions. This is sounding good....:-)
      12-07-2013, 01:56 PM   #8
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6328
Thanks again!
That's not for front or rear. Just average drop height. The eibachs retain factory level I believe. I would just get coil overs instead of shocks and springs. Same price in the end and complete adjustability.
      12-08-2013, 09:20 AM   #9
masz4m
Drives: 07 Z4MR
According to eibach's website:
Front: 0.8 in
Rear: 0.4 in
This is actually not too bad....
Thanks!
      12-08-2013, 09:54 AM   #10
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
I think coilovers are overkill for the average person that is looking for new shocks and a tiny amount of drop unless they really want a certain amount of drop.
Besides the adjustability (and who really adjusts them after the initial setup?) what is the benefit when comparing properly built shocks and springs to properly built coil overs? Also, don't you also have to get an alignment each time you adjust them up or down?
      01-17-2014, 08:56 AM   #11
vicj
vicj's Avatar
Drives: '06 M Roadster; 2010 Mini
I agree. I've had ten, yes TEN, coilover set ups on my M. I haven't met a set yet that I find livable on the street. I thought the best I had was TC Kline, Double adjustable, set full soft at all times. I've had issues with the bearings in the Camber plate not holding up though, and I'm sick of the D/A noise in the front shocks. So, I'll be going BACK to springs and shocks.
