      08-18-2013, 07:02 PM   #1
Krypptic
Drives: E92M, GT3
Toyo R888 for minimal daily driving
The car sees 1-2 track events a month. Besides those miles, the car gets maybe 100 miles a month of street driving.
I have put off for the time being getting a track set of wheels, because it seems it will be better to have a new suspension on then see what wheels will fit versus the other way around.
So will it be too many heat cycles to be worth it until I have a track set or am I not doing enough driving for it to make a difference?
      08-18-2013, 07:27 PM   #2
gmd2003
gmd2003's Avatar
352
NTO-1 is a better tire for your purpose , and in general the R888's turn to garbage quickly due to cycling out , while the 01's are good to the cords . If your rim diameter is an issue due yourself a favor and buy a set of 18 inch rims . By the way I think the NTO-1's were quicker too , I've used both . The BFG rivals are good option for you as well , but don't handle heat quite as well as the 01's but have a similar R comp stiff sidewall turn in feel .
George
      08-18-2013, 07:34 PM   #3
Krypptic
Drives: E92M, GT3
Thanks George. I will look into both.
On a side note, sorry to read about your accident. At least you're ok. ESS needs to help you sort this out.
      08-18-2013, 08:54 PM   #4
dre99gsx
Drives: 1994 Toyota Supra
I run R888s street duty. They whine at high speed. They are excellent tires on my Supra for spirited driving.
      08-19-2013, 12:27 AM   #5
The HACK
The HACK's Avatar
1821
For that sort of duty, STORAGE is a bigger issue. The car doesn't get moved enough and you will have flat spots develop on the relative soft R-comps with the chassis sitting on the tires. Still better to store the spare R-comps off of the car, and swap before events.
