      08-13-2013, 08:29 AM   #1
sd_dracula
Drives: 2020 G20 330e
Will these fit
I have an E86 3.0si with stock turbine wheels and was wondering if the wheels below will fit. They have on offset of 25 and 8.5" width all round.
Some people say yes, some say no.
What is the lowest offset the e86 can take?
      08-13-2013, 09:40 AM   #2
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
The front may take some work, the rear should fit. A squared setup on that car might not look ideal. Spacers maybe?
      08-13-2013, 11:01 AM   #3
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
I have 19x8.5 +15 on the front of my e85 right now and the rim is just flush with the fender.
You'll need a 215/40/18 tire for the front and spacers for the rear.
      08-13-2013, 11:43 AM   #4
sd_dracula
I actually went and put the rim on and it is sticking out quite a lot on the front arch. 5-10cm I'd say so spacers will only push it further out.
The rears should be good.
      08-13-2013, 04:50 PM   #5
Endless619
DHS
Endless619's Avatar
Drives: 2023 M4, 2020 Land Rover
215 is S2000/Miata sizes. Very thin and small. I would like to see 265s at a minimum in the front..
2020 Land Rover Velar Autobiography
2023 BMW M4
2016 X3
      08-13-2013, 07:01 PM   #6
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
I know my 180hp can be too much for the road sometimes, but I manage :P
Back with my e46 M3 though I was running 265/35/18's in the front
