      04-03-2014, 10:00 PM   #1
Beemerism
Drives: z4
Question Tire Pressure warning light after changing wheels?
Hi all,
The light came on after I put M parallel wheels on my car. It is a 2003 so I guess it has the FTM type. How can I fix the light or is there anyway to reprogram the module to learn the new wheel speed?
Old tires are 225/45/17 --> Diameter = 24.97 in
New front tires are 225/40/18 --> Diameter = 25.09 in
New rear tires are 255/35/18 --> Diameter = 25.03
      04-04-2014, 05:24 AM   #2
Shipkiller
Shipkiller's Avatar
Drives: Me
Press and hold the TPM button for 5-10 seconds. Drive off. Unless you have a fault the system re-zero's and the light will go out.
