      03-14-2014, 09:33 PM   #1
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
Will these HRE's fit?
I have tried to do my due diligence before posting a question about wheel fitment. Most people running 19x10's in the rear usually have the offsets from et 20 to et 26. The reps from HRE are suggesting the following fitment for Z4M:
19x8.5 et 30 (this appears to be within the range that most people use: 32-40)
19x10 et 40 (most are running et from 20-25-26)
I'm concerned about the 19x10 et 40.
Also, interested in Michelin PSS's: This seems to be a common configuration:
225/35/19 F
265/30/19 R
Also, this set up is going on a stock suspension for now...may go with coil overs in the future.
Any suggestions or guidance would be appreciated.
      03-14-2014, 10:38 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
Et40 is for z4 non m.
those are the tire sizes im using in pss as well on the same size wheels. Great fit
instagram: @ dubsesd
      03-15-2014, 09:38 AM   #3
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Yep, don't buy x10 ET40.. too soft!
      03-15-2014, 11:03 AM   #4
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I have 18x9 et 40 in the back, with a 20mm spacer. Effectively et20
      03-15-2014, 01:34 PM   #5
nekky
Wagon life
nekky's Avatar
Which is still too soft and you want to buy my 18x9.5 +35 18x10.5 +22 set for $2500 US shipped right now
      03-16-2014, 03:36 PM   #6
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
Thanks dubsesd for your advice. Ok... Optimally I would like to use your specs as close to yours as possible:
19x8.5 et 35
19x10 et 26
Their recommendation of 19x8.5 et 30 seems more aggressive than a et of 35 in the front.
Your thoughts?
      03-16-2014, 07:26 PM   #7
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
It will still work fine. 8.5 et30 is what I am going to be using on my new set of wheels. The most agressive you may want to go without adjusting camber settings
      03-16-2014, 07:32 PM   #8
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
Thanks dubsesd. I appreciate your help. I look forward to seeing your new wheels.
