      10-24-2013, 12:18 PM   #1
z4msteve
Drives: '07 Z4MC
18x10 275 Square
Met this guy over the weekend at the LSC BMWCCA DE, one of the most aggressive fits I've seen for the track, but he was very fast so I know it works for him.
-4 degrees in the front on AST 4150. He said that he tried it with KW Clubsports but the perches rubbed. The wheels are Enkei NT03+M with +25 offset.
Last edited by z4msteve; 03-13-2014 at 03:43 PM.. Reason: The wheel offset is +25 , not +22.
      10-24-2013, 04:08 PM   #2
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Nice to know that the ASTs are skinnier than KW Clubsports. I don't understand how my Clubsports can be so chunky either lol.
      10-24-2013, 05:36 PM   #3
Expert@ApexWheels
Expert@ApexWheels's Avatar
3525
Drives: M3
The KW struts are not the issue, it's due to the helper spring and longer length main spring that they use in their KW Clubsports that causes the perch to sit much lower than the AST setup that is likely to only use a 6" linear spring. 18x10" with 275/35/18 on the Z4M is mighty impressive though!
      10-24-2013, 06:51 PM   #4
nekky
Wagon life
nekky's Avatar
Thanks, David!
Any way to safely remove the helper spring/switch out the stock KW spring to something that will perform just as well yet increase clearance??
      10-24-2013, 06:55 PM   #5
Expert@ApexWheels
3525
Drives: M3
Thanks, David!
There have been customers that have removed the helper spring without any issues besides from a little bit more noise coming from the suspension. Others have also added torrington bearings to help alleviate that noise. Removing the helper spring should bring the spring perch high enough so that you would not have wheel and tire clearance issues anymore. Otherwise, switching to a 6" length linear race spring would be the best solution.
      10-25-2013, 06:53 AM   #6
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
The owner of the red car is a member here, I had a LOOOONG talk about his setup. The car was hooked up for sure, Frank was running down everything out there. I sure makes me lean hard toward going the same way on my car.
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      10-25-2013, 03:27 PM   #7
nekky
Wagon life
nekky's Avatar
So simply upgrading to a 6" race spring and no helper is what is needed?
Thanks a lot, David!
      10-25-2013, 04:49 PM   #8
Expert@ApexWheels
3525
Drives: M3
That is what we have learned from the customers that have used the KW Clubsport suspension. They had mentioned that the KW spring perches had to be slightly modified to fit the 60mm springs since the KW Springs ID are 61mm, but the modification was worthwhile to be able to change out springs.
      10-26-2013, 06:07 PM   #9
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
I have remove the helper springs on my Clubsport right now with the KW front spring and it gives more room for tires/wheels. I had Hyperco springs before and didn't modified the springs perches.
Anyway at my ride height the helper springs were useless because they were always fully compress even when the wheels didn't touch the ground...
      10-29-2013, 12:07 AM   #10
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
I have 5"+helper springs on my AST 4150 and the perch sits above tire with just a little preload of the helper.
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      03-13-2014, 02:13 AM   #11
S2000
Drives: E86 Z4M, E60 M5, E92 M3
I owned that Red Z4M and just stumbled upon the pictures on the web.
I liked that setup a lot:
- The wheel offset is +25 , not +22.
- I used 5" 616lb Swift Springs + helper in the front and 5" 728 lb in the rear
- I used Turner camber bolt to get -4 camber, without it, the Vorshlag can get up to -3.4
- When driven hard, -3.4 degree still wearing more on the outside, at -4, I got even wear at the track but it wears too much on inside when driven on the street.
I don't have the car anymore and am now experimenting with E92 M3.
I have the stock OEM shocks/springs, driver OEM heated memory seat , stock wheels with 90%/5 months old street tires (Conti Extreme Contact), spare 5" swift springs and 6" KW springs for cheap sale.
      03-13-2014, 05:31 PM   #12
sabbanick
Drives: 08 SBM M coupe
i have same wheel on MCS suspension run about 3.3 degrees neg camber. never looked back car feels much more composed with less understeer on turn in whether at local a/x event or track.
