      06-24-2013, 09:52 PM   #1
seank
enthusiast
seank's Avatar
48
ESS 525 installed
Haven't been able to get on it, since its raining today oddly in June. Will give feed back later this week.
What I have noticed so far:
-very driveable and doesn't feel like crazy hp below 5000 rpms in 4th gear.
-idle is a little auscilating at times. Not sure if this is normal.
-a little whinny but I am not sure if it is better than the sound of an air intake mod.
-makes less noise through the euro headers as before FI
-the parts are a very tight fit in the front of the car.
More later this week.
      06-24-2013, 09:58 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
Looking forward to hear more of your impressions.
instagram: @ dubsesd
      06-24-2013, 11:07 PM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
*yeah, its not a torque beast in gears 4-6
*my rpms fluctuate by about 50 up and down sometimes, not un-usual. New coils and plugs do not help
*my afe intake sounded much deeper. This is more like an airline jet sound. You learn to like it. Sounds best at full throttle high RPMs
      06-25-2013, 02:50 AM   #4
Str8 RippiN
Str8 RippiN's Avatar
48
Drives: E46 ZCP ///M3
can't wait to read your review, i was thinking going 525 from my 445 or back to NA with an evolve box with cams...
-Tommy
"The Zillenium Falcon" mod journal - http://www.m3forum.net/m3forum/showthread.php?t=440670
      06-25-2013, 03:19 AM   #5
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Grats!
      06-25-2013, 06:44 AM   #6
gmd2003
gmd2003's Avatar
352
It takes a lot of miles for the ECU to adapt, slowest adaptation ever for me , I thought something was wrong with the kit for a 150 miles lol.
      06-25-2013, 06:47 AM   #7
gmd2003
gmd2003's Avatar
352
Weird , the torque is what is most impressive in 4th gear and up in the 525 kit for me ?
George
      06-25-2013, 08:00 AM   #8
Beedub
sean i get no fluctuation at all during idle its rock steady..... Tq is very good on my 500 kit which is admittedly making way more boost than it should.... keep an eye on the clips... boost leaks are so obvious on this kit as performance drops like a stone!!
heres an idle clip....
from 1.50 onwards.... note it doesn't move an inch!! ignore the rest....
the blower sounds like shit during breakin and some of them continue to make a tin can rattle.... mine got much better after i did the initial 2000 mile oil change, intake noise i dont get the jet sound really.... the exhaust drowns it out, from inside the cabin it sounds like it did before with a muffled Blow off noise....
adaption did take ages.... dont be afraid to explore the rev range, it needs to adapt everywhere just be mechanically "respectful"
      06-25-2013, 08:56 AM   #9
seank
enthusiast
seank's Avatar
48
Thanks for the tips guys. With the odd June pouring rain, I have only put 30 miles on it. I will keep you updated later. I was just giving initial impressions and I haven't had it above 4500 rpms with the rain.
I wasn't sure if it was going to adapt, since it is Alpha N now.
I did find some Setrab cooling ducts (commonly used on the porsches, which I am thinking about how it can be modified to increase its cooling if needed for the track guys:
http://i10.photobucket.com/albums/a1...ct3640x480.jpg
http://www.racerpartswholesale.com/i...4760_popup.jpg
      06-25-2013, 10:07 AM   #10
Pheonix
2007 BMW/Z4MC  [0.00]
Awesome. Thanks for the updates! I think we should have a Bay area Z4s get together soon
      06-25-2013, 11:05 AM   #11
seank
enthusiast
seank's Avatar
48
Agreed.
      06-25-2013, 01:36 PM   #12
Str8 RippiN
48
is there another manufacturer besides zionsville that makes an aftermarket radiator for our car??
-Tommy
      06-25-2013, 02:24 PM   #13
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
Very glad to hear i'm not the only one haha. After initially installing it and driving around I thought there was almost no upgrade but now after putting on a solid 400KM the car is a lot more open.
///M - Some Mods 'N Stuff
      06-25-2013, 03:20 PM   #14
seank
enthusiast
seank's Avatar
48
George did some research on this on page 4 or 5.
http://www.zpost.com/forums/showthread.php?t=847633
As far as i know, he ordered it, so you will be able to see how the results are as well as fitment. He's the guinea pig.
Good to hear.
      06-26-2013, 06:50 PM   #15
seank
enthusiast
seank's Avatar
48
Well, I will say that the car doesn't scare the hell out of me, so I would have definitely been unhappy with the ESS 445. The torque is great 1st, 2nd, and 3rd, but for me and 100 miles seems to not pull very hard in the upper gears (nice, but as Beedub says "i always want more power.")
I have the P3 gauge coming this week, so I will be able to make sure the AFR's are in-line, as well as being able to check on the boost. I have heard that the intercooler is susceptible to leaks.
It is very drivable. Oil temperatures are 10-15 degrees higher than it used to be, which i think is mostly because of the oil cooler not having a low pressure behind it. I will be fixing that, and showing updates.
      06-26-2013, 07:48 PM   #16
VinnieAces
VinnieAces's Avatar
Ive got the exact same initial impressions
      06-27-2013, 05:09 AM   #17
Beedub
i don't know what the climate is like by you, but honestly in sub 10 deg C the car is a completely different animal, its soooooo effected by outside temps its crazy, much more than any other FI car that ive owned.... in my cold ass country the car is Tq-y, revs like a a mofo and just flat out is nuts.... when the weather gets mid to high 20's, ( not often) it seems kinda sluggish after a while..... My AFRs are 11.5 at redline.....
consider meth/water injection huge gains to be had..
my oil temps are cooler 90% of the time compared to stock and it manages really well at the track too, recovery times are excellent, then again the sprint work my car see's are very hard but shortish timed laps....
i really need to get rid of the stock cats as i think they are restricting my final HP number, sadly right now money is super tight!! ( always the way)
Consider a catch can, the amount of oil that finds it way back into the system is alarming imo.... i STILL get some even with a very effective CC install but a good deal is caught so i'm happy with that!!
good luck and enjoy....
      06-27-2013, 02:40 PM   #18
seank
enthusiast
seank's Avatar
48
Is more vibration common at idle? It is noticeable while sitting at a light. Not annoying. Just noticeable.
The bottom middle clamp came off. The reason that I noticed it, is I was unsatisfied on how much was able to be clamped, so I ordered a longer silicon hose on initial install and better clamps that I put on today. This might help, if there was pressure loss.
Also, I have a duct being made for the oil cooler. It will also close of the area behind it between the radiator which should flow better. I will take pics and let you know if it drops the oil temperatures a little.
      06-27-2013, 02:49 PM   #19
Beedub
i get alittle more vibration at idle, but then again i have the comp spec VT engine mounts, its barely noticeable however.
      06-27-2013, 03:41 PM   #20
gmd2003
gmd2003's Avatar
352
Oh check molded plastic intake piping it tends to rub on the hood. Putting a piece of foam at the spot greatly reduced my vibration at idle . But especially with catless headers that is normal to some degree.
George
      06-27-2013, 05:48 PM   #21
seank
enthusiast
seank's Avatar
48
George
I will look at that. I just didn't notice it a few days ago.
BTW, it 37 degrees Celcius in Sacramento.
      06-28-2013, 10:25 AM   #22
seank
enthusiast
seank's Avatar
48
George
Thanks for the tip. It was rubbing on the strut tower.
