      08-05-2013, 07:09 PM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Is my belt tight enough?
I recorded a video, I'm putting moderate pressure on it, pulling with my left hand. The hydraulic tentioner was replaced in January with an OEM unit.
Or do I just have a crappy belt on the car?
      08-05-2013, 09:00 PM   #2
seank
enthusiast
seank's Avatar
48
That looks like yours is stiffer than mine, especially from that angle. It may be the belt or try a 5mm smaller belt, but I don't think you should change the tensioner.
      08-05-2013, 09:43 PM   #3
ZStig
279
thanks for the verification. It would definitely be suspicious if the fairly new OEM tensioner was already weak
      08-05-2013, 09:53 PM   #4
dre99gsx
Drives: 1994 Toyota Supra
Rule of thumb is you should be able to twist the belt no more than 90 degrees.
