      08-06-2023, 02:52 PM   #1
DCAT1000
Drives: z4m
Need Help with OEM Nav wiring setup
Hey guys, a while back I had a few mods done to my Z4M (evolve airbox, Quaife gear driven diff) and was experimenting with weight reduction, so I removed half of the audio & nav items from my 2007 Z4M (DVD, telematics, speakers, amp). I stopped short of removing the radio and nav while I was searching for an OEM radio block plate for the dash. I also removed all of plastics rear of the seats, and studied what it would take to remove the bulkhead.
If you have ever done this then you know how much space is required for all the parts that get pulled off. 6 months later, the wife says put it all back on the car.
All went fine except that the nav dash has no signal from the audio. Nav screen is powered, and the manual buttons to move screen work, but will not show any information from the car system or audio. Radio works fine and manual buttons on steering wheel work fine too. I am convinced I just missed a simple wire connection.
Can someone who has a nav setup take a few pics of the wiring connections and post here? I already had my local BMW mechanic invest 1 hour into investigating, but they are mechanical guys and not car audio (not sure they can read a wiring diagram).
Big thanks!
2007 Z4M Coupe, Interlagos Blue
      08-18-2023, 04:39 PM   #2
DCAT1000
Drives: z4m
Nevermind. I figured it out. Had to take all the center console plastics off again, and simply re-plug in the wiring into the back of the cd player/computer. All good now!
