      01-21-2013, 04:46 PM   #1
RADRACR
RADRACR's Avatar
Different tire brand on front/rear... acceptable?
Is it just faux pas or will it have handling consequences? I'll save you the trouble and myself.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      01-21-2013, 05:14 PM   #2
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
For the street, it's not that bad. I will have RE11 front and RS3 rear this summer.
For the track, try to avoid to mix different thread wear, tires brand. They won't react the same to temperature and won't grip/loose grip at the same time.
      01-21-2013, 05:24 PM   #3
RADRACR
RADRACR's Avatar
But this is the case with the same tire anyway, isn't it? Front and rear dynamics are quite different. My main concern is tramlining. Reason I ask is I want 255 in front and the only tire I can find in that size is RE-11. Then NT05 on rear because they're cheaper.
Off Topic: How is the RE-11 vs RS3?
      01-21-2013, 05:36 PM   #4
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
RS3s have 255, and probably Star Specs. EDIT: Just saw you run 19s.
You get to the point where you get different slip angles, sure...the tires heat up differently weather it be inside tire, outside tire...front/rear.
But, if you get different tire, now you play with different sidewall deflections and slip angles. For example, RS3s require huge amounts of slip angle to get maximum grip, where as the Star Specs do not. With this, you will not satisfy the front w/out disrupting the rear...and vice versus
