      06-02-2013, 01:04 PM   #199
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Good info and pictures! Thanks!
      06-05-2013, 04:53 PM   #200
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
...not powerflex.
The ones I ordered are out of the UK and are offset.
Check here... http://www.superflex.co.uk/proddetai...od=SF095-2558K
& here http://www.ebay.co.uk/itm/BMW-Z4-M-O...30855932966%26
Just arrived - fast shipping from the UK! Manufacturer is Australian.
2006 Z4MC - #LL93158
      06-05-2013, 05:08 PM   #201
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
      06-05-2013, 06:21 PM   #202
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Still waiting for RE to ship the RTAB's. Ordered at the same time? No correspondence from RE?
      09-22-2013, 09:15 PM   #203
GuidoK
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
I've found a third supplier of offset bushings beside the previously found superflex and bavarian auto/whiteline offset bushings.
http://www.nolathane.com.au/
They're maybe affiliated with whiteline? (both australian and some drawings are in the same style)
Edit: they're based at the same address.....
Strangely they (nolathane) have 2 variants of the 66mm offset bushings:
http://www.nolathane.com.au/product_...t_number=45553
http://www.nolathane.com.au/product_...t_number=45555
the 45555 have "LH offset - RH standard alignment" whatever that means.... (a lefthand offset bushing and righthand non offset?!? does that work?!? )
      09-24-2014, 08:55 PM   #204
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Hey shipkiller,
How did these work out?
I bought a set of these, but never installed them.
Any issues?
Thanks..
Originally Posted by Shipkiller View Post
I have a few pictures but when it started to get really hard, I just forgot to take any.
I think these are actually Whiteline N52606 bushings. These are very stout.
The bushings on the car before removal.
I have a three jaw puller. Pulls the bushing right off..
Pressing out the bushing.
Cleaning up the carrier. Removing burrs and such.
Placing and aligning the new bushing to be pressed back into the carrier. The alignment mark on the bushing must be aligned with the alignment mark on the carrier.
Because the bushing fits rather snug on the end of the control arm (worse than a virgin on prom night), you need a tool to get them on the arm. A HAMMER is not enough and you risk damaging the ball joints on the control arm.
I manufactured a tool similar to the $200 BMW tool for $8.00 in parts from HomeDepot. It only took around 45 minutes to make.
      09-25-2014, 04:55 AM   #205
Shipkiller
Shipkiller's Avatar
Drives: Me
Originally Posted by BookerM3 View Post
Hey shipkiller,
Any issues?
Thanks..
I have had them on the car for a year and numerous track days. No issues.. Just a PIA to install.
      01-11-2016, 02:28 AM   #206
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
...not powerflex.
hey, how are these holding up for you? by reading your posts, its plug and play correct? Did any company come up with a bushing as well?
      01-11-2016, 07:38 AM   #207
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
They are holding up great.
Yup, plug & play
      07-15-2016, 01:16 PM   #208
DanFromTucson
Drives: Z4 M Coupe
Am I to understand that the Superflex bushings are easier to install given the multi-piece design? If I have to make special tools to bolt in the lollipop, I may not be interested in this as a DIY job.
Thanks in advance!
      07-15-2016, 01:31 PM   #209
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks in advance!
You need a 3 arm puller to get the bushing off of the control arm regardless which bush you use.
If you want easy, just get OE with bush and lollipop complete
Anything else you will also have to press out the old bush from the lollipop before pressing in a new one.
      07-16-2016, 04:23 PM   #210
DanFromTucson
Drives: Z4 M Coupe
Well, now both are on the car. The one piece units need two persons to get them on.
Oh, Pal, these were offset bushings.
Thanks inTgr8r.
I was referring to Shipkiller's post above. He seemed to be implying that the 2-piece units might be easier to reinstall.
I figured I would get a machine shop to press out the old bushings and press in the new ones. I just didn't want to get everything back together and find out that I couldn't bolt the lollipop back onto the car without fabricating tools.
I have 50K miles on the M Coupe, and I'm trying to figure out how far I want to go with a suspension refresh. My FCABs actually look fine, but while I'm in there doing struts...
      07-16-2016, 08:58 PM   #211
Shipkiller
Shipkiller's Avatar
Drives: Me
If you are using stock FCABs, the you should have no issues getting them back on.
If you look closely at the pictures, I am not using anything near stock, so they are really, really stiff, and I had a hell of a time getting the bolt holes to line up.
The 'Whiteline's' I used are stiffer than the Superflex or Powerflex FCABs.
