      01-12-2012, 09:26 AM   #23
partlowr
partlowr's Avatar
Drives: BMW Z4 Roadster
Sorry for resurecting such an old thread but it sounds like several of you know what your're talking about pertaing to the H&R spring set-up. I have a question pertaining to my Non-M Z4 3.0i and H&R springs. I just purchased the H&R springs for my car, do any of you know if a 15mm pad (or any size for that matter) is recomended for Non-M's to get it leveled? I would rather go spend the extra couple bucks on the pads now and and install it now rather than doing an instal and not being happy with the appearence or performance and have to go back and play with it again. I know most of you guys own M's so you might not be able to answer but I am not even familar enough with these cars to know the difference between M and Non-M suspension components. Thanks
      01-26-2012, 02:23 PM   #24
partlowr
partlowr's Avatar
...any help on this guys? I want to install my springs ASAP but I want to know if the 15mm pads are recomended(or even fit) for non-M with the H&R springs? Thanks in advance.
      01-26-2012, 04:02 PM   #25
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
you dont need a pad with the non-m. it will sit lower overall than a z4m with h&r's as well
instagram: @ dubsesd
      01-26-2012, 10:18 PM   #26
partlowr
partlowr's Avatar
Thank you. I'm going to install them this weekend.
      04-09-2012, 11:54 PM   #27
J-Thurm
Drives: 2007 bmw z4 coupe 3.0si
I also ordered a set of H&R springs for my non-m z4 coupe. Will I need to get anything to make it look more slammed? Just wish I could tuck my tires a little. I am running 19's right now and want to get it as low as I can. Thanks.
      04-10-2012, 11:04 AM   #28
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
to tuck, you need coilovers
      04-10-2012, 11:53 AM   #29
davesz4mc
Drives: 2007 z4mc
roffle you get those perches put in the front? looks interesting to put those on and then pull the rear pads. Do the rear springs run ok without the pads?
      04-12-2012, 06:55 PM   #30
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2009 Bmw 135I  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
I just installed my H&R lowering spring today and I dont found it that stiff like what other users' feedback, actually I found it just like OEM feel with nice drop tho. is it because the spring not fully settle yet or our oem spring was stiff enough that I couldnt make a difference?
some pics here
      04-15-2012, 08:24 PM   #31
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Thats about the same drop I have on my M with the springs.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      04-16-2012, 08:33 AM   #32
strokeZ
strokeZ's Avatar
Drives: '11 e92 M3 6MT
Mine is lower than that with H&R springs. Hard to tell here but only photo that I have access to right now.
      04-16-2012, 12:17 PM   #33
ZStig
279
Those lowering perches are not compatible with the z4m. Not sure about the regular z, but doubt it. U need some sort of pads, and the oem are very thin anyway
      12-14-2012, 02:55 AM   #34
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
Anyone else have pix of non-M's with the H&R springs? I'm having trouble justifying the H&R Coilover set for my "beater."
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
