      12-28-2010, 06:23 PM   #23
F360C
Drives: E86 S54
Yep I do know where they cut the corners and the only thing was the camber plates. And really it was not cutting a corner just not the best way to have the adjustment. I have even said this many times. Other then that one small issue they are just as rock solid as the TCK. So I don't know how I am defending them? If you notice I pointed this out in my initial response to this thread. I didn't try to hide the issue. Two me both these kits have an issue each. The TCK have the noises and the GC have the weird adjustment of the camber plates. Based on this I don't know how you could say one kit is better then the other. I could say that TCK put out a kit that has clunks and bumps. Based off this they are "A company that KNOWINGLY puts out poor products belongs at the bottom of any list. If they purposefully put that little care into any product that IMO all their products are compromised." At least with the GC you could order them with out the camber plates and put the same camber plates on that TCK uses and have a kit that has no issues
07 Z4 M Coupe AW/IR
      12-28-2010, 08:47 PM   #24
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by F360C View Post
Glad to hear they were able to fix the issues with this kit! I wonder if they will replace shocks in the earlier kits that have the issues?
I heard that TCK does help buyers of older kits with noise matters. I was lucky to have gotten a kit that was already updated
      12-28-2010, 09:31 PM   #25
F360C
Drives: E86 S54
That's great to hear. You really can't go wrong with either TCK or GC. They both make solid suspensions and stand behind their products
07 Z4 M Coupe AW/IR
      12-28-2010, 09:42 PM   #26
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
If you had it to do again, would you use a different camber plate than the one supplied with the GCs.
IIRC there was a write up on these, but haven't been able to dig it up yet.
      12-29-2010, 10:34 AM   #27
F360C
Drives: E86 S54
Its hard to say really. Although I dislike the way the GC plates adjusts there are some features I do like about them. First let me tell you why I dislike the way the GC plate adjusts.
In order to put in more camber you must pull out caster inorder to reach one of the bolts. Then you set the camber and then put the caster back in. With other plates, even alot of GC's, you can just put more camber in without having to touch the caster. This would for sure be easier but doing it the way these plates are set up just really involves one extra step. If I could have everything else the same and have it adjust the way most camber plates adjust then that would be ideal. I set mine once and have not touched them at all through out the year so the adjustmetn process is not a huge deal to me because I don't have to use it often. Maybe once or twice a year. Now there two features that I like about the GC plates which would make me keep choosing them even though the adjustment procedure is not the easiest.
The two things I like about the plates are the bearing design and the fact that you can choose between three different types of plates.
There is a nice write up on the GC web site about the bearing design they use in these plates. I am not going to re-write it all but suffice to say I think it is better then the other options out on the market. This is totally personal opinion though. Now the other reason why I like the GC plates.
GC lets you choose between three types of plates. Street, Hybird, and Race. One thing I have forgot to mention is that I am pretty sure that the street plate adjusts just like any other plate on the market because it lacks the caster adjustment. My one big reason for liking the GC plates was the hybird plate. It lacks pretty much all the rubber of the street plate but has alittle bit just to make sure there is no noise. Another member on here, GP20, and I had an extensive convo before he bought his GC kit about weather the hybird would make noise. He was worried it would but he installed his and was happy to report that it is pretty much silent. It is nice to have the better performance of less rubber in the suspension but also have something that is quiet.
I am not going to say the GC plates is better then the TCK plate because they are both solid products but the reasons above would make me choose the GC plate again if I did it over.
07 Z4 M Coupe AW/IR
      12-29-2010, 10:56 AM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks for the great write up.
That really helps.
      12-29-2010, 11:22 AM   #29
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
      12-29-2010, 01:26 PM   #30
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
TCK's are on sale right now...
Down to the GC's and TCK's...
      12-29-2010, 02:13 PM   #31
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
TCK camber plates are a bit of a kicker.
      12-29-2010, 02:56 PM   #32
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
$500 worth of kick
      12-30-2010, 08:07 PM   #33
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Looks like the GC's with 500 F and 600 R springs along with the Hybrid race/street camber plates. I may add the sway bars too (need more thought to this). I'm going to call GC next week to work the specifics and shipping details; no UPS
Thanks for all the feedback Guys!
      12-30-2010, 09:07 PM   #34
F360C
Drives: E86 S54
Congrats! How come it can't shit UPS?
07 Z4 M Coupe AW/IR
      12-30-2010, 09:21 PM   #35
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^because with UPS to Canada it's rape & pillage time.
They bludgeon you to death on brokerage and border fees.
      12-30-2010, 09:34 PM   #36
F360C
Drives: E86 S54
Yea I used to hate when I had to have stuff shipped north of the boarder because I needed it right away. The UPS bill almost always seemed as large as the bill for the items
07 Z4 M Coupe AW/IR
      12-31-2010, 08:00 AM   #37
RBull
Drives: 2007 M Coupe
I had to use them with my former company. Negotiated a $35 flat fee inclusive per shipment for US importation regardless of # of pieces or weight. Sounds like on the retail side they gouge.
      12-31-2010, 08:01 AM   #38
RBull
I may be ready in spring of 2012.
I've got other things on the list before that.
The Koni yellows will do for now.
      12-31-2010, 07:03 PM   #39
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
307
Drives: '07 M Coupé & '16 435xi GCoupé
I've had my GC set for almost a year now, and I would do it again without a doubt. My M sees mostly street use so the GCs are really more than I would ever need. As far as the GC camber plate issue is concerned, it's not much of an issue. For the type of use my car gets I never really need to adjust camber settings. I've got it balanced just right for daily street use with occasional canyon carving days.
So far still no noise and ride is firm but comfortable.
      01-02-2011, 12:45 PM   #40
nofear
nofear's Avatar
72
Drives: P
I have TC kline on my MC,KWs on the M5 and M6,if it wasnt for the darn valve noise on the kline set up,I would say ,i like it far more than I do the KWs
      01-02-2011, 10:39 PM   #41
Master Apex
Drives: '17 F80 M3 '07 Z4M '06 E60M5
KW Clubsport comes with built-in camber plate and stiffer spring for ~$3000
http://www.zpost.com/forums/showthread.php?t=407156
      01-07-2011, 08:11 PM   #42
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Thanks Everyone! F360C!
Jay at GC is unbelievable. Spent 40 minutes with me today working out my requirements and explaining the dynamics of different setups. Worked with me on shipping options too! UPS Canada
      01-07-2011, 08:55 PM   #43
RBull
^sounds like you're ready for a great set up. Let's get those babies to Canada and installed.
      01-07-2011, 09:24 PM   #44
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ +1
....so I can try them.
