      06-22-2022, 10:52 AM   #1
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
E86 Cooling
Is the blue BMW coolant ok to use?
My temp needle rests slightly above the 1/2 mark. However, it's also 114F here in SoCal.
Thinking about using Red Line Water Wetter. Thoughts?
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      06-22-2022, 12:45 PM   #2
pungo
pungo's Avatar
Read the coolant temp for accuracy to know the actual temp before determining if you have a cooling problem. I've only used the blue BMW coolant.
      06-22-2022, 04:34 PM   #3
wdb
dances with roads
wdb's Avatar
4732
The thing about coolant is that it is a chemical compound. You want to be absolutely certain that the chemical compound being pumped under pressure inside your hot engine does not actually eat said engine. Do homework. Make a smart choice. Mostly, don't freak out just because your temp gauge went up a needle's width in 114 degree weather in stop/go traffic.
