07-27-2014, 02:57 PM | #1 |
Rep 247
to suck or not to suck...
I'm about ready to do my 3rd oil change, I have bought the suction tool to suck oil from the dipstick, works great but I feel like I'm not getting it 100% empty. I bough the new drain plug and I just wonder if I'm being OCD by wanting to drain the oil from from under the car, my thinking is that I will get all the oil and whatever debris is in there...I'm I over thinking this?
| 2008 Interlagos Blue Z4MC | | AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust | |
07-27-2014, 03:08 PM | #2 |
M = Midlife Crisis
65
Rep 2,006
I get more oil out of it with my Mityvac than I do by draining...
2006 Z4MC - #LL93158
07-27-2014, 03:10 PM | #3 |
636
Rep 3,124
If you're going to replace the drain plug seems like a waste of time to suck.
What kind of drain plug? I put in a magnetic Dimple plug (SS M12X1.5X12) from BavAuto. I was surprised to see how much swarf came out the next change. Been clean since. I don't know if it was just 100k miles worth of rings, or bits of my broken vanos exhaust hub. Nice to know it's not in there any more.
07-27-2014, 03:50 PM | #4 |
Rep 247
the past two times I sucked the oil out, I bought the oil change kit from Tisher, it comes with a new plug..I'm kinda curious to see whats stuck to the magnetic plug..at 50k should I continue to suck oil or drain?
07-27-2014, 05:47 PM | #5 |
Rep 247
well I got bored and drained the oil, turns out it must have been done this way before b/c the plastic cap was missing, and BMW never replaced the drain bolt with a new one ( still hex OEM plug)
All and all, not bad I feel better about it knowing that I got 99% of the oil removed...on to the next project..
07-28-2014, 06:02 AM | #6 |
Rep 400
I believe only M3's had the plastic cover over the oil drain bolt. My M Coupe didn't have one and TIS infers that prying off the cover is e46 only. I've got a mightyvac rig. I usually alternate between sucking and draining.
07-28-2014, 07:23 AM | #7 |
Rep 247
Wasn't sure, I found a diy and it said remove cover, wasn't there..but I think I'm going to alternate between sucking and draining...wasn't too bad getting under there and draining..
07-30-2014, 12:48 PM | #8 |
Rep 228
my 3.0i has a door under there, it catches oil fantastically and blows sh*t all over the floor!
bags are for groceries. |
07-30-2014, 07:15 PM | #9 |
636
Rep 3,124
This plastic cover?
I have one. It didn't have one when I bought it used. I expect mechanics don't bother to put them back on.
