      12-29-2012, 06:02 PM   #1
shakemyhand
Drives: 2007 Z4 Roadster 3.0i
Step by Step Oil and Filter Change..........
I own a 2007 Z4 3.0i Roadster and have looked everywhere trying to find some clear information on how to change the oil and filter on this car. Can someone help me find where this information is or help me with a step by step DIY procedure. Thanks, Mike.
      12-29-2012, 06:44 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
N52 Engine, right?
Here's a DIY video.
Others:
Written DIY 1 or written DIY 2.
Plenty here on the forum if you need help with jacking up the car, etc.
      12-29-2012, 07:43 PM   #3
shakemyhand
N52 Engine, right?
Here's a DIY video.
Others:
Thank you so much, thats just what I was looking for. Do I have to buy the BMW oil? What would you recommend that I run in it? Thanks, Mike
      12-29-2012, 08:41 PM   #4
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
Full synthetic 0w30, 5w30, 0w40 or 5w40 oil is fine from any manufacturer if you change more frequently than BMW recommends (such as twice as often). If you keep close to BMW's change interval, then use only LL01 oils; in North America, the only readily available oils that meet this spec are BMW 5w30, Castrol Syntec/Edge 0w30 and Mobil 1 0w40.
      12-29-2012, 09:19 PM   #5
Shipkiller
Shipkiller's Avatar
Drives: Me
Amsoil also meets the LL01 spec.
      12-30-2012, 03:05 AM   #6
shakemyhand
I just bought this car recently and am trying to learn about it, from what I understand there is no dipstick, how do I check the oil level on it? Thanks.
      12-30-2012, 06:13 PM   #7
Pete C
Pete C's Avatar
Drives: '08 Z4 SI
With the engine fully warm while driving press the small rectangular button between the tach and speed that has a tiny clock symbol. It's next to the s/r button for the odometer. You will get a display on the odometer showing a level graphic and saying "oil OK". This digital dipstick isn't very accurate so never add oil unless it's half low. I usually check mine while driving on the level but up and down hills read the same
      12-30-2012, 08:26 PM   #8
shakemyhand
Thank You for the information, thats a big help.
