      03-18-2023, 10:35 AM   #1
klaussca
Drives: 2004 BMW Z4
Past Oil Change
I could not find this topic anywhere, but is there a way to tell when or how many miles ago the last oil change was done. I just bought a 2004 BMW Z4 and there is no documentation about maintenance.
      03-18-2023, 11:05 AM   #2
Steeler
Steeler's Avatar
2429
With unknown maintenance it would be good due diligence to change all fluids and applicable filters.
      03-18-2023, 11:15 AM   #3
Piper1
Piper1's Avatar
Drives: E85
If they reset the service interval you’ll see a count down for mileage to oil change at initial start on the dash then it goes away like after 5sec or so from key turn. That’s a big IF. When I got my e86 from a non bmw dealer they changed the oil pre sale. I changed it as soon as I got home with not knowing what oil/filter they used. Just that anal to not want to take any chances. It’s one of the easiest and cheapest things for our cars to do yourself for piece of mind.
      03-18-2023, 11:32 AM   #4
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
If you are going to keep the car for a while then it is a good idea to invest in changing all the fluids.
If the PO didn't do dealer maintenance you can bet the rear diff and transmission oil have never been changed before, same with flushing the brake fluid.
It might just be me but when I get a new toy I want to start fresh from a known base, new sparkplugs, coils, filters, injector cleaning, flush all fluids/oils.
At least then you know that none the cars systems are wearing out prematurely.
2008 E86 M coupe
      03-18-2023, 01:19 PM   #5
klaussca
Drives: 2004 BMW Z4
Thank You everyone, I am planning on doing the liquids anyway, but always nice to find the little tip and tricks.
