03-09-2023, 07:48 PM | #1 |
Rep 59
Are they a perfect fit? Megan Racing Headers
Just picked up a set of Megan Racing Headers for my Z4M and I wanted to know if they are a perfect fit - I know they will bolt up to the section 1, but does it clear the FCAB and all the heat shielding around the engine? Wanted to know if anyone has first hand experience installing these on their car. Thanks!
03-09-2023, 08:07 PM | #2 |
Rep 781
Depends whether they were the first ones they made or the later ones,
the later ones are a perfect fit. The first headers they made you have to get all the screws in first but keep them loose, once they all have caught a few threads then start tightening them down equally. As I remember there was only a couple of holes that were off a bit but enough to make it a nuisance.
2008 E86 M coupe
03-09-2023, 08:43 PM | #3 | |
Rep 59
03-10-2023, 07:40 AM | #4 | |
Rep 781
Regardless, it's not really an issue just a nuisance.
2008 E86 M coupe
05-11-2023, 10:12 PM | #5 |
Rep 104
Drives: 2006 Z4MR
05-11-2023, 10:16 PM | #6 |
Rep 104
Drives: 2006 Z4MR
OK... I found a few other, later posts which seem to confirm you are very happy with the purchase. What sort of tune did you end up going with?
05-16-2023, 05:31 PM | #7 |
Rep 59
05-16-2023, 09:25 PM | #8 |
Rep 104
Drives: 2006 Z4MR
That's awesome... 335whp is nuts for our car without FI. Did you also have them relocate the secondary O2 sensors and EGR, or did you tackle the install yourself?
05-17-2023, 09:24 PM | #9 |
Rep 429
Another happy megan header owner here. Installed them myself. Was perfect fit. Clears FCAB, all bungs are in proper places, lines up with section 1. Couple years and no cracks I can detect, welds look good. Running Epic tune and engine seems quite very happy. Not sure how much power its putting down but I also have AFE dry filter in stock box, m3 intake elbow and RPI mufflers + air scoop.
One thing to note though. Do not use the included manifold gaskets! Buy genuine bmw. |
grannyknot951.50 |
05-17-2023, 09:28 PM | #10 |
Rep 104
Drives: 2006 Z4MR
OK then! Might message you with a few detailed questions the about install process. My order is set to be delivered tomorrow, but it will be a few weeks before I have time to install. And already ordered OEM manifold gaskets and the two that mate up the headers to section 1.
05-18-2023, 08:19 AM | #11 | |
Rep 429
05-18-2023, 11:15 AM | #12 | |
Rep 59
05-21-2023, 08:37 AM | #13 |
Rep 104
Drives: 2006 Z4MR
Got it. Good reference/website! I also picked up an O2 sensor wrench thing. Will see how that goes.
05-28-2023, 08:13 PM | #14 |
Rep 104
Drives: 2006 Z4MR
Using the universal joint to remove the nuts holding the header to the block was priceless advice from billswebspace! The old headers are out, and tomorrow, the new ones will go in.
grannyknot951.50 |
05-29-2023, 09:51 PM | #16 |
Rep 59
