      04-28-2015, 10:54 AM   #1
whatcubed
Drives: e46 330ci
Double-pull unlock on door handles - possible to change?
So I've had my M Coupe for about 7 or 8 months now and I've gotten used to all the odds and ends, but one thing I'd be interested in changing is how the doors unlock. The double-pull unlock is problematic not so much for me, but for passengers who aren't used to it. The final straw that makes me ask about it is I took my father somewhere the other day, and I thought he was going to rip the handle off trying to get out of the car.
I've done some googling and not much comes up, so have any of you tried this? Can it be coded out with a OBD2 tool? Any help would be appreciated.
      04-28-2015, 11:34 AM   #2
torchmedia
Drives: White Z4MC
^ Agreed, I cringe every time someone gets out the first time and I forgot to teach them the rules
      04-28-2015, 12:17 PM   #3
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
I haven't run into this issue as I have the drive-away locks disabled.
I would just disable that and no more need to double pull.
      04-28-2015, 12:56 PM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
I double pull the doors on all our other cars now.
      04-29-2015, 10:32 AM   #5
whatcubed
Drives: e46 330ci
How do you do this?
I still attempt to depress the clutch whenever I drive an automatic car sometimes haha.
      04-29-2015, 10:34 AM   #6
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Originally Posted by whatcubed View Post
How do you do this?
Can be coded. I had mine done at the dealer when the car was still under factory warranty.
      04-29-2015, 10:58 AM   #7
Drives: M2 Comp
there used to be a check list arround here for of the many things that could be coded
.....there is definitely one on B'fest posted by Ron Stygar
      04-29-2015, 11:30 AM   #8
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
For those familiar with NCS Expert you can disable auto-lock when you drive away with the following in your GM5 module:
VERRIEGELN_AUT_AB_X_KM/H
Set this to nicht_aktiv to disable entirely. To clarify, when you disable this you will have to lock your doors manually afterwards.
Or you can disable it by specific key with the following lines:
VERRIEGELN_XKM/H_SENDER_1
VERRIEGELN_XKM/H_SENDER_2
VERRIEGELN_XKM/H_SENDER_3
VERRIEGELN_XKM/H_SENDER_4
Set any of these to nicht_aktiv to disable the feature for that key.
As others have noted, there's no real way of addressing the double-pull issue without a workaround. Disabling the "drive-away lock" feature is just a band-aid solution to those who still want to lock their doors without the double-pull unlock.
Hope this helps.
2008 Z4 3.0si Coupe
      04-29-2015, 02:34 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm pretty sure I saw this setting in Progman, as well, which may be a little easier to do than NCS Expert.
      04-29-2015, 11:46 PM   #10
whatcubed
Drives: e46 330ci
I think disabling the pull-away locking will work. I'll look into getting it coded, a couple good shops near me can probably take care of it.
Thanks for the help, all.
      04-30-2015, 06:35 PM   #11
pungo
pungo's Avatar
Disabling the pull-away locking will do the trick, but that opens you up to a car jacking.
Pressing the unlock button on the center console should work too.
      05-01-2015, 11:06 AM   #12
Taylorguy74
Enthusiast
Drives: 2016 550i M-Sport
Yes, it is on there. Toggle on/off.
I would rather have mine on for auto-lock and then I unlock the doors once I set the parking brake when I'm shutting down and getting ready to get out. Driving with unlocked doors to me is a hazard in it's own right.
2016 550i M-Sport
2008 328i M-Sport (Sold)
2007 Z4M Roadster (Sold)
