      08-11-2014, 03:09 PM   #23
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Ok, here's the 4 pin connector. If there is an intermediate connector so I can get it to connect to the yellow connector, do you know what that part number might be?
      08-11-2014, 04:50 PM   #24
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Problem solved. The intermediate connector was still on my original seats. Now, the only light that is on is the dash passenger seatbelt/airbag light for the passenger side. The passenger airbag light on the center console used to be on even though the airbag was turned on with the key by the passenger side door. I think all I need to do now is someone to reset the error code. Thanks for the help!
      08-11-2014, 05:24 PM   #25
WestCDA
Drives: 2006 Z4R 3.0si
Glad to hear you tracked it down the missing wiring. Make sure you pass that info along if you resell your old seats, as that purchaser is going to be up against the same thing ...
      08-12-2014, 08:03 AM   #26
2278
Congrats bud, glad to hear you got it sorted out. I knew the seat install would be pnp =)
