      06-17-2014, 07:45 AM   #23
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Good luck, I hope it gets resolved before your track day!
      07-14-2014, 11:52 PM   #24
sabbanick
Drives: 08 SBM M coupe
any updates?
      07-15-2014, 07:45 AM   #25
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Sadly I can say that no solution has been offered by Evolve at this point. Several solutions have been attempted thus far (so I've been told) but no success. I will keep you guys posted on any updates.
      07-15-2014, 08:32 AM   #26
sabbanick
Wonder if they will sell the box w/o cable and software at a slight discount. Have you considered different software....say EPIC?
      07-16-2014, 09:53 PM   #27
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I wouldn't go that route. You will get finger pointing between vendors when you have problem.
      07-17-2014, 05:07 AM   #28
sabbanick
I agree to disagree
      07-17-2014, 11:38 AM   #29
C-los
Drives: 2013 M3
Buy Air Box without Programming. Purchase Supercharger programming from ESS (or another company), get the fuel and timing maps redone by tuner, profit?
Long way to go about it, but you'll get the Alpha N tune done without (hopefully) any hiccups
      07-18-2014, 07:21 PM   #30
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
Evolve, Any updates on the heel-and-toe issue?
      07-19-2014, 12:52 AM   #31
sabbanick
the trials and tribulations of creating a great product.
      07-21-2014, 10:17 PM   #32
Cybmx
Drives: 06 Z4MR
+1
      07-23-2014, 03:56 PM   #33
C-los
Drives: 2013 M3
Personally i'm looking to you Evolve's air box because their kit includes the tune.
But if they cannot get it tweaked, I may have to go with VAC's Kit and find my own tune like ESS or something...
Would really prefer the Evolve kit though. .. . .. .
      07-23-2014, 04:01 PM   #34
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Drives: 635/1815, X3M Comp
Evolve has been here at Zpost recently promoting their GB.
I'm sure they would've posted an update if they fixed the issue.
      07-23-2014, 05:08 PM   #35
fullerra
fullerra's Avatar
14
test test  [0.00]
VAC does not have a kit despite what their website says. I had my airbox installed at VAC (because they put in camshafts at the same time). They said they used to have a kit, but it never panned out, and they just haven't taken it down from the website.
      07-24-2014, 09:47 AM   #36
angelr
Drives: 07 aw/ir m coupe, 2013 S4
Has anyone ever driven their z4m without the maf plugged in? It ignores throttle input under those circumstances. Almost certainly related.
      07-24-2014, 12:06 PM   #37
C-los
Drives: 2013 M3
I like this guy, thinks outside of the box there... I think you may be on to something if not related, in the right direction; but, their problem is when depressing the brake pedal, they lose the ability to control/actuate the throttle.
Once they release the brake, the throttle works normal again....
Definitely a great idea, and checking all relations of the MAF to the throttle and brake assemblies and pcm functions is definitely a good place to start.
Great idea Angelr
I wonder if i can find some pinouts and sensor function maps for our cars.... hrmmm....
      07-24-2014, 03:21 PM   #38
angelr
I've been watching this thread for a bit now as I'd love to go with an evolve box myself when finances allow (if i can resist the urge to boost it). I was checking fuel trims and a few other things on my m the other day and while driving around with the maf disconnected I noticed that the car would ignore any throttle input whilst the brake pedal was depressed...figured it's a strong possibility that they are related. Not to assume that evolve isn't already aware of the relationship but you never know. They are replacing the maf with the speed density setup but the ecu doesn't know that as such.
I have a shop with diag, tuning, dyno and fabrication ability so I spend some of my down time screwing around with stuff. In fact if I can convince myself that I'll still be able to track it, the m may end up turbo charged in the near future. The tuning hurdle should be something we can overcome given our ties with various tuners, some of whom are very well versed with the oem architecture.
      07-25-2014, 11:45 AM   #39
C-los
Drives: 2013 M3
That's pretty interesting there. I wouldn't have though about that. I apololgize, i didn't even think that you would have actually check on that relation. That's my fault and I apologize for being disrespectful about that.
I wonder... For those of you with this issue, do you still have your MAF laying around? if so, would you mind plugging it in and seeing if this corrects the issue? I'm talking to my BMW guys and seeing if they can get me a funtions and pin out diagram of the MAF, T/B and PCM so i can see where the relation is and why it is there.
I know mazda's (where is work) the MAF and T/B are connected, as well as the alternator for some retarded reason. Used to get cars coming back after air filter jobs, come to find if you don't connect the MAF sensor completely, the light comes on. Plug it in, bam, all fixed.
      07-25-2014, 11:58 AM   #40
C-los
Drives: 2013 M3
Hrmmmm, a second thought on this.. just had a reverse brain fart (if that makes sense.)
ESS uses alpha N for their tune as well. I wonder, (since i dont' own one i dont' know) could it be they leave the MAF plugged in just for the IAT sensor (that's built into the MAF)? This could be what keeps everything right for them... They Run an AlphaN, use the MAF internal IAT, and since the MAF is plugged in, it doesn't trip the throttle ignorance.
****Any Supercharger guys chime in on this?****
But with the VAC Air box, You remove the factory MAF completely, and run the CSL IAT on the side of the box. These deletes the MAF portion, which actually DOES trip the throttle ignorance portion.
So in theory, You could split the wiring by unpinning the wires for the IAT, run those separate for the CSL IAT in the Box. Then leave the OEM MAF attached and hidden somewhere so the throttle works as designed. ( the PCM/DME would ignore it even if it's plugged in due to AlphaN Programming.)
Now, if this theory all holds true, then i wonder if there's a way to reprogram the computer to ignore MAF signal so the throttle continues to work without the MAF plugged in. It might be easier to find at this point, considering we would know the exact cause.
      07-25-2014, 12:11 PM   #41
angelr
No worries C-los I didn't think it offensive in the least.
Your post follows my reasoning and the reason I posted about my observations. Hopefully it might assist with getting this sorted for those affected. I know I wouldn't be happy if I didn't have that ability.
      07-25-2014, 12:13 PM   #42
F360C
Drives: E86 S54
You guys should check with Epic... word on the street is they have a tune already made that works and from some pics I have seen on the net user "sixspeed" is already using it.
07 Z4 M Coupe AW/IR
      07-25-2014, 07:01 PM   #43
Krypptic
Drives: E92M, GT3
FWIW, I emailed them awhile back asking if they had a map for our cars since they do tunes for e46 alpha n, but got no response if they had an e86 alpha n tune.
      07-25-2014, 09:08 PM   #44
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I thought sixspeed was working with Evolve?
