06-18-2013, 11:57 AM | #24 | |
enthusiast
48
Rep 1,695
06-18-2013, 05:40 PM | #25 | |
Rep 13
I've heard horror stories about indie shops, and I don't think the dealership will install non-OEM parts. Any advice for shops in the Austin/San Antonio area? I'll even take it to Houston or Dallas if there's a more reputable place. I would guess most people would discourage someone with moderate skills to attempt this repair? |
06-18-2013, 06:23 PM | #26 | |
enthusiast
48
Rep 1,695
06-18-2013, 06:31 PM | #27 |
Rep 2,138
Drives: Me
seank is correct.
The biggest pain is to remove all the interference from under the car so as to be to able remove the oil pan. That is a big job. Plus, you have to have the steering angle sensor recalibrated and an alignment afterword, but I am not that sure about the alignment. I thought about doing this myself in the garage but seeing just what has to come off the car.... screw it. Let someone who knows what they are doing and has done it before do it. Plus, I trust these guys. And they will let me watch... |
06-18-2013, 09:42 PM | #28 |
Rep 2,867
If they let you watch, then take plenty of pictures and videos
Sad to see such high lead reading on a relatively low mileage car. You got me worried now since I only have an easy 24k miles on mine. Might need to start doing oil analysis |
06-18-2013, 10:04 PM | #29 |
Rep 855
This is the last thing I want to see Guess I should get an oil analysis too.
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
06-18-2013, 10:23 PM | #30 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
I try not to overreact as these engines have been around awhile since the bearing recall in the older m3's. But its hard not to I admit. Ugh
06-19-2013, 04:57 AM | #31 | |
Rep 2,138
Drives: Me
The S54 has only two weaknesses that I can determine. The Rod Bearings and the Vanos. The only way to tell with the rod bearing is to do an oil analysis. With the vanos, you just wait. If this is all too much and you are losing sleep over ‘what might be’ then sell the car and get a Honda. At the end of the day ‘it’s just a freaking car’, you can buy another one. |
06-19-2013, 06:04 PM | #32 |
Rep 400
This is maintenance that can be planned and budgeted for. Just don't redline it very often and keep the revs below 4000 until properly warmed up. I still rev to about 7500 rpm regularly. I had a sample of 22 ppm then the next one's were around 8 ppm. I plan on using coated bearings when I do mine later this year or next. I do an oil analysis every oil change.
07-01-2013, 12:38 AM | #33 |
636
Rep 3,124
Just ordered the collection kit.
Changed my oil yesterday, and as I was pouring the catch pan into old oil containers for recycle I noticed that the sludge in the bottom of the pan had sparkly swirls of glitter in it. I checked the filter and looked inside the oil fill, and I don't see any glitter. Need to get a new pan. I've been using this one for at least 10 years on 5 different cars. The glitter is probably from the Camry that my Daughter drove 70 miles with no oil in it, after Jiffy Lube drained it and forgot to refill it. 2 days later she tells me that there's been a red light on her dash since she went to Jiffy Lube and wondered if that was normal. Car ran fine for about another 6 months before she wrapped it around a pole and totaled it while texting. (She's fine. Well ...not injured.) |
02-17-2014, 10:52 PM | #34 |
Rep 13
Well I finally bit the bullet and bought a new set of bearings. I swapped them out this weekend. I initially set to buy the BW treated set, but I had terrible customer service. They were back-ordered for over a month, and BW kept calling me to push out the expected delivery date. This forced me to keep rescheduling the garage time. After the second extension, I was fed up and I cancelled my order. I ended up ordering a similar (maybe they're the same) set from Epic Motorsports. They had them to me the same week.
While I was at it, I also put in the ARP rod bolts and used a stretch gauge to measure the clamping force. This method seemed to work pretty well. Only time will tell. Here's a picture of the work space. ...and sadly here are my bearings. I think it's safe to say they're original to the car which means they have a paltry 36k miles on them. Cylinder 1 on Left to Cylinder 6 on Right. Rod side is upper and cap side is lower. You can see the rod side of the bearings are pretty worn. I only use the Castrol TWS Motorsports oil. I'm always careful to keep it below 3500 rpm until the oil is up to at least 190F. Maybe the PO drove the car hard? |
02-17-2014, 11:20 PM | #35 |
Rep 2,867
Wow...looks like you did the right thing by replacing those bearings. I'll be doing my 1st Blackstone analysis this week with only about 28.5k on my '08. Wish me luck
02-17-2014, 11:37 PM | #36 |
636
Rep 3,124
I just sent in my second sample today at 98.5k miles.
First one at 93k came back clean. Fingers crossed. Good call with the ARP rod bolts and stretch gauge.
02-18-2014, 04:39 AM | #37 |
Rep 2,138
Drives: Me
There is a reason the Bimmerworld (BW) are on backorder. The bearings that BW uses are not manufactured any more.
BW had a supplier for the BMW Motorsport Racing Bearings that were only available in Europe and then they sent them to WAC for treating. BMW has discontinued the manufacture of those bearings. The last five sets BM had were sold in Sept. or Nov. Two of those sets went to my buddies shop here in Va Beach. Now BM is trying to find a bearing supplier of an bearing (other than OEM bearings) to test and see if they are better than the OEM bearings. It sounds like BW corporate is not talking to sales or there are issues behind the scenes we will not know about. I might be able to find out......... Of course BW is not going to tell you (the consumer) all of this information because if handled properly, you (the consumer) does not need to know this. It looked like it was not handled properly. |
02-18-2014, 11:11 PM | #38 |
Rep 13
I was told the Epic Motorsports Bearings received the same type of treatment as the BW bearings did. Does Epic not use the European Motorsports bearings? Why are they not having supply problems?
I assumed they were the same since they use oddly similar images on their websites: BimmerWorld Epic Motorsports |
02-20-2014, 09:01 AM | #39 |
Rep 2,138
Drives: Me
I would 'assume' that Epic uses OEM bearings and has them treated by WPC.
What was explained to me is that, the BMW Motorsport bearings were only available in Europe and not imported by BMW to the US. (There are MANY BMW parts only available in Europe and not available in the US. M3 CSL parts are just one example. Not sure why BMW does this.) Bimmerworld (BM) had a supplier who could get the Motorsport bearings, import them into the US cheaply for BM. Now the BMW Motorsport bearings are not being produced and the supply has dried up. James Clay (BM) has been searching for a non-OEM bearing that will give better performance than the OEM bearings. I am going to assume they still have not found one.... What I think is that at this point in time, your only choice is the OEM bearings and have them treated by WPC (Epic) or coated (Randy or VAC). If you need bearings, you need bearings... |
