05-05-2015, 05:44 PM | #1 |
Rep 23
Suspension Replacement!
Wondering what everyone suggests for strut and shock replacement for 2007 Z4M Roadster? OEM or aftermarket? What brand?
I do have 19" wheels. Not wanting to spent thousands on coil overs! Last edited by heligarret; 05-05-2015 at 05:45 PM.. Reason: add car model |
05-05-2015, 07:23 PM | #2 |
Rep 904
How many miles are on the car? No need to spend thousands on coilovers. A set of Megans can be had for under $1k. You mention you don't want to buy coilovers, but you also said you're just looking for shock/strut replacements. Are you keeping your stock springs? If you also want to replace your springs, do you want to keep it at stock height or is a slight drop ok?
05-05-2015, 08:37 PM | #3 |
your average JAMF
3099
Rep 4,093
At 41k miles I replaced my shocks with Bilstein HDs. Kept stock springs, run stock 18" rims with Michelin PSS. Firmer than stock (which were well-worn by the time they were replaced), all in all, the "right" replacements for me. And should last 100k miles or more, warranted for life to original purchaser.
'21 M2 Comp
'19 Golf R |
05-06-2015, 12:52 PM | #4 |
636
Rep 3,124
I did the same at about 80k. (Yea, they were shot).
Replaced everything except the springs. Used RE rear upper mounts.
05-06-2015, 03:27 PM | #5 | |
Mechanical Engineer
96
Rep 1,025
My car is at 88k. My front springs are at 88k, but my rears are only at about 25k due to replacement from the typical broken spring problem. |
05-06-2015, 04:07 PM | #7 |
636
Rep 3,124
Hmmm.
I had imagined that the springs would be largely indestructible. I hadn't heard of "typical broken spring problem" until now. Search results show plenty of destructability. Looks like it's environment dependent. Something else to keep an eye on. j2h^3, you're where I am. Surprised you had that happen around here. Seems to be due to rain + salt.
05-06-2015, 11:43 PM | #8 |
your average JAMF
3099
Rep 4,093
I've never heard of the springs breaking in a dry environment - seems to be confined to snowy/salted road areas. But it sounds like one failed in Pasadena - about as good of an environment as possible. Hmm.
'21 M2 Comp
'19 Golf R |
05-07-2015, 03:02 AM | #9 |
Rep 874
05-07-2015, 07:54 AM | #10 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
I took out my stock shocks at 82k miles and they were still working fine, on top of that I had H&R springs on for the last 20k miles too. I ended up going to H&R Coilovers and am very happy with them so far.
If you really want low budget and were completely happy with stock setup, there are lots of guys who took their OEM suspension off early and they probably still have it lying around for cheap. Just an idea. |
05-07-2015, 08:52 AM | #11 |
Rep 10,662
Yep! I had H&R SPs on my last Z4M and hope to order another set for my newer Z4M soon. I loved 'em! Be sure to get the RE RSMs too OP!
05-07-2015, 10:44 AM | #12 |
Rep 874
I didn't change my RSM, maybe I should have. But I think the car is firm/stiff enough as is. If it was a track car I would have changed them out.
05-07-2015, 01:38 PM | #13 |
Rep 1,269
Maybe I've been spoiled by my previous TCKline & Ground Control coilovers. When I test-drove a Z4MR with H&R coilovers, I thought the suspensions were garbage. Stiff for the sake of being stiff but also the handling was nowhere near as good as the TCK's & GC's. It was a dreadful 5-minute drive. I'd even say that the H&R springs with Bilstein dampers handle better and are more comfortable and simply make the Z4M more fun to drive than the H&R coilovers.
05-08-2015, 07:52 PM | #14 |
Rep 23
Car has 80,000 miles. Running 19" wheels. Don't want the ride any stiffer and really like how the car rides. Pretty sure the fronts are done. Still undecided
05-08-2015, 11:59 PM | #15 |
636
Rep 3,124
I still recommend the Bilstein HDs. I think they're pretty much stock stiffness but may be more durable.
I didn't notice any extra harshness. Still rides like the same stagecoach.
05-09-2015, 12:18 AM | #16 |
1621
Rep 4,294
i went for Bilsteins HD and HR springs, beaut setup, (on recommendations of Shippy) and he was spot on. my oem stuff was shot though, it had 120Kmiles on it, so no wonder.
Powered by Last edited by Vanne; 05-13-2015 at 10:03 PM.. |
05-09-2015, 12:55 AM | #17 | |
Mechanical Engineer
96
Rep 1,025
Over on one of the other Z4 forums (can't remember which one), they have a thread tracking the broken rear spring problem. Last time I saw it they had something like 100 people who had posted with the same proboem. I was mostly wondering if they lose any of their stiffness over time, etc. I think the breaking issue was probably a manufacturing defect, as I can't recall seeing anyone having the issue a second time after replacing the original set. |
05-13-2015, 02:13 AM | #18 | |
701
05-15-2015, 08:53 AM | #19 |
Rep 904
05-19-2015, 04:29 PM | #20 | |
Rep 28
Shocking..
My car made it over 200k without an issue. I would say the primary contributor to this issue is your PARKING. Parking on inclines take a HUGE toll on the suspension. The handbrake is there to protect your car just in case, not to park it. Soon the handbrake will also stop working if you park on slopes too much. |
05-19-2015, 04:38 PM | #21 | |
Rep 1,990
The E85 M Roadster utilizes the same basic MacPherson strut/multi-link suspension design as the standard E85/E86 Z4 range. However, it has been substantially modified by BMW M GmbH with the following changes: -wider front track (by half an inch) -revised lower aluminum front control arms with a design similar to that of the E46 M3 -steering knuckles bolted directly to the front struts -larger and stronger rear subframe designed to accommodate the M Differential Lock -modified longitudinal links in the rear suspension -modified wheel bearings -specific spring and shock rates -thicker front (27 mm) and rear (21.5 mm) anti-roll bars |
