05-02-2021, 09:21 AM | #1 |
Rep 141
07 Z4M Roadster 95k miles/Complete Part Out
*Prices/availability updated August 1st, 2023* I have a 07 Z4MR w/95k miles in for a complete part out. Car has been ran and driven for about 30 minutes and everything went through for functionality. Roof motor does not work. Rims not for sale. Local pick up is preferred at 39201 but can ship anything small or large within the US at the best rates. Price list for most parts below, contact for any other inquires/part #’s/parts/specific pics/shipping quotes/etc. PM or text at 601-760-0325. Thanks DME/EWS/Immobilizer/key set - $1,000 Brake booster (w/o master cylinder) - $50 M sill set - $120 Tail lights - $170 each Quarter panels - $180 each Door shells - $150 each Door handle outer - $25 each Door glass/window - $60 each Window regulator - $50 each Right mirror - $120 each Coolant tank - $30 Fender liners - $40 each rear - fronts sold Front subframe/cross member - $80 Deck lid - $180 - SOLD Fuel pump - $80 - SOLD 6 speed trans swap set (transmission, pedals, clutch, flywheel, related trans parts, etc) - $1,400 -SOLD Steering rack w/lines/tank/steering column shaft/pump set - $700 - SOLD Sun visors - $40 - SOLD Exhaust mufflers: $100 each side - SOLD Intake box assembly - $175 - SOLD Upper console/rear cover tray - $50 - SOLD X pipe exhaust section - $100 - SOLD Shift boot/knob (heavy wear) - $40 - SOLD Left mirror - $120 - SOLD Center air vent - $75 - SOLD Headlight control switch panel - $60 - SOLD Engine cover - $80 - SOLD Dash (non nav) - $250 - SOLD Steering wheel w/trim & airbag - $400 (one trim piece broken) - SOLD Soft top/rear glass - $350 - SOLD Rear subframe/cradle - $200 - SOLD Differential - $1,000 - SOLD Driveshaft - $600 - SOLD Drive axles - $220 each - SOLD Rear bumper - $500 - SOLD Mid section (mid cats) exhaust: $350 - SOLD Headers - $700 - SOLD ABS brake pump - $550 - SOLD Seats/door panels set - $1,400 - SOLD Brake caliper set F&R - $500 - SOLD Aluminum trim set - $300 - SOLD Intake manifold - $200 - SOLD Clockspring/control stalks - $50 - SOLD Center console - $100 - SOLD Rear/behind seat speaker cover - $30 each - SOLD Park brake boot/handle - $40 - SOLD Cluster - $650 - SOLD Radio - $100 - SOLD Engine (tested/driven) - $4,500 (140-150 compression all cylinders, leak down test 2-4% on all cylinders except cylinder 5 at 14%, added a little oil to it and retested and came back at 2%. Suspecting worn oil sleeve/ring on piston. Video of engine running is available and car was driven and ran for over 20 min and runs great and pulls well) - SOLD Last edited by danbmw1; 08-05-2023 at 10:48 PM.. Reason: Price/stock adjustments |
05-02-2021, 11:16 AM | #2 |
And yet
32
Rep 67
Just messaged you!
SunUpTopDown363.50 |
05-04-2021, 11:00 PM | #8 |
Rep 141
06-04-2021, 04:26 PM | #9 |
Rep 141
Bump/update. Many parts still available. Updated on sold items, price drop on some items.
Also have another Z4MR for part out soon which may have some of the same parts that have already sold from this one, as well as a few non-M roadsters and one non-M coupe, will make individual posts for each car as I get to them but if you need anything feel free to PM. Sorry to anyone who I may have been delayed with on responding, have a lot going on with lots to take a part. Most stuff on this car in particular is already off and ready to ship. |
06-29-2021, 09:10 PM | #12 |
Rep 141
The ones from this car are sold but I have another set of door panels in great shape from another Z4M. You can send me a text at 601-760-0325 and I can get you some pictures if you're interested. They're nappa leather and I was going to sell them as a set with the seats but can work something out for the right deal.
01-13-2022, 11:34 PM | #13 |
Rep 141
Bump, list updated, also have several non-M E85/E86 Z4s for parts so if something is sold from this car chances are it's something I may have from another.
01-25-2022, 09:42 PM | #14 |
Rep 2
Just created an account so can't PM.
1) "Right mirror - $120 each" --- is that just for the glass or the whole mirror assembly? Is it auto-dimming version? 2) How much for the DSC sensor (aka speed sensor) located under passenger seat? Thanks! |
01-26-2022, 12:55 PM | #15 | |
Rep 141
Not quite sure what sensor you're referring to but we'll figure it out with some diagrams/pics. Send me a text at 601-760-0325 and I can send you pictures and we can go from there. Thanks |
04-17-2022, 10:22 PM | #17 |
Rep 541
Drives: 13 LRP M3,06 E91 325,88 E30 M3
Hi, I'm looking for the round plastic cover on either side of the center console to cover the screws which fastens the the console.
If you still have them, can you provide a price shipped to 48301? Thx
88 E30 M3 Alpine White/Cardinal Red
01 E36/8 Z3C Hellrot II/Extended Walnut/5 spd (1 of 1) 06 E91 325xiT Barrique Rot/Terra/6 spd (1 of 1) 08 E86 3.0si BSM/Extended Blk/6 spd (1 of 3) 13 E92 M3 LRP ZPP/ZCW/DCT (1 of 200) |
04-21-2022, 06:08 AM | #19 | |
Rep 781
and #51167906699 but at $20 - $28 a piece looking for used ones is understandable.
2008 E86 M coupe
04-21-2022, 05:38 PM | #20 |
Rep 541
ECS doesn't have it in stock and they don't have an ETA. Even FCP is out.
04-21-2022, 05:46 PM | #21 |
Rep 781
The first part number is.
2008 E86 M coupe
04-22-2022, 09:37 AM | #22 |
Rep 541
Thanks bud!
I went by this part # from realoem. Must be an old part #'s.
grannyknot951.50 |
