      02-11-2014, 04:49 PM   #45
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Originally Posted by David@ApexRaceParts View Post
We have not had direct experience with the BF Goodrich Rivals, but from what we've been told by our customers, the Rivals fit similar to the Hankook R-S3's, so it should still work with your Z. At a lowered ride height, since these tires run wider than a normal street tire, you may want to roll your rear fenders in order to avoid fender rubbing.
For most street tires, the rears can take the 275/35/18 tire size on either the 18x9.5" ET22 or 18x10" ET25 rear wheel fitment. However, any summer performance tire, such as the Hankook R-S3 or Dunlop Star Specs, would require you to roll the rear fenders for the 275/35/18 size. If you are looking to avoid rolling fenders, those summer tires in the 265/35/18 size would be a better option.
Hi David, I'm confused. In response to my question, you indicated that 275/35/18 RS3 would work fine, but above you say that you'd need to roll the fenders.
      02-11-2014, 05:00 PM   #46
Expert@ApexWheels
Expert@ApexWheels's Avatar
3525
Drives: M3
I apologize for not being clear. At a stock ride height, some cars have been able to get away with no fender rolling at all, but if you are lowered at all you would want to roll the rear fenders. In most instances, using a 275/35/18 extreme performance tire has the possibility of rear fender rubbing. We usually recommend a fender roll in the rear even if it does clear without rubbing to avoid any possibility in the future should one lower their vehicle.
      02-11-2014, 05:06 PM   #47
intoflatlines
Thanks for the clarification!
      02-12-2014, 01:52 AM   #48
Beedub
fwiw... and anyone interested.... im running clubsports Set relatively high and running a rear 265/40/18 (checkout the fat sidewall) on an 9.5 ET23 right now..... it doesnt rub at full compression. but as you can see my ride height is definitely conservative...... and maybe that tiny bit higher offset maybe further helping too ??
http://s75.photobucket.com/user/cahzz1/media/file_zps12cb9a35.jpg.html][IMG]http://i75.photobucket.com/albums/i2...ps12cb9a35.jpg[/IMG][/URL]
      02-12-2014, 04:29 AM   #49
evel karnievel
braaap
evel karnievel's Avatar
Germany
44
Drives: Z4M QP
@beedub: can you post more pictures from your car with M260 wheels?
      02-12-2014, 09:31 AM   #50
intoflatlines
Originally Posted by Beedub View Post
fwiw... and anyone interested.... im running clubsports Set relatively high and running a rear 265/40/18 on an 9.5 ET23 right now..... it doesnt rub at full compression. but as you can see my ride height is definitely conservative...... and maybe that tiny bit higher offset maybe further helping too ??
I imagine 275/35/18x10 ET25 would be just fine on stock suspension, as David suggested then. Thanks!
      02-12-2014, 04:05 PM   #51
Beedub
sorry i havent got any further pics..... will make a thread when summer comes, england is currently swimming
excuse thread derail....
      02-18-2014, 03:38 PM   #52
Steenos
Drives: 2007 Z4M Coupe
2021 BMW M240i  [0.00]
2007 M Coupe  [0.00]
I just cannot smiling every time I look at my car. These wheels are incredible. I notice the steering is a lot lighter in the turns. Sorry this is an iphone picture but I will get real pictures soon.
2021 m240i on order
      02-18-2014, 05:08 PM   #53
Expert@ApexWheels
3525
Drives: M3
Looks great, thanks for sharing Steenos!
      02-18-2014, 05:15 PM   #54
Steenos
2007 M Coupe  [0.00]
Thank you David. I'll send you pictures here soon from a real camera and it nice and cleaned up.
2021 m240i on order
      02-22-2014, 10:57 AM   #55
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
Anthracite APEX EC-7 - 18x8.5" ET35, 18x9.5" ET22
• Michelin PSS - 235/40/18, 265/35/18
2007 BMW ///M Coupe
      02-23-2014, 05:33 PM   #56
Expert@ApexWheels
3525
Drives: M3
Awesome photos Rekla, thanks for sharing!
      03-08-2014, 02:01 PM   #57
Steenos
2007 M Coupe  [0.00]
Here's one of mine all cleaned up!
2021 m240i on order
      03-08-2014, 06:44 PM   #58
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
18x9.5 +35 squared
      03-10-2014, 02:36 PM   #59
Expert@ApexWheels
3525
Drives: M3
Awesome Zs, thanks for sharing Steenos & i2ichal2dZ4M.
      03-10-2014, 10:43 PM   #60
Gladius
Two Wheels or Four?
Gladius's Avatar
Drives: '18 Perf Edition m240i
Current: '18 AW Performance Edition m240i
Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci
      03-10-2014, 10:59 PM   #61
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Now running 18x9.5 et35 (et30 with 5mm spacer) front and 18x10 et25 rear with the APEX stud kit on 255/35/18 front and 275/35/18 rear Michelin PSS. Big thanks to the guys at APEX who helped me with fitting the Stoptech brakes up front!
Z4M_0053 by M detaR, on Flickr
Z4M_0177 by M detaR, on Flickr
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      03-11-2014, 02:15 AM   #62
Beedub
and that tyre runs wide as well so that rear is like a 280mm... the car is doing well to swallow those, hows the rub on aggressive driving??
      03-11-2014, 12:13 PM   #63
Expert@ApexWheels
3525
Drives: M3
Awesome photos, thanks for sharing Gladius, and Rated M Roadster!
      03-12-2014, 06:45 PM   #64
Rated M Roadster
160
After putting the PSS tires on, I actually raised the car up a bit and took some camber out (will double check what my camber settings are at). There was a little additional rubbing on the liners from swapping tires, but nothing terrible. After the 5mm spacer though, and instead of adding some camber, I rolled the front corner of the fenders where the bumper meets.
      03-15-2014, 08:45 AM   #65
avsbmw
Drives: 07 Z4MC
      03-17-2014, 05:32 PM   #66
Expert@ApexWheels
3525
Drives: M3
Your M coupe looks great avsbmw. Was your car wrapped or repainted?
