      02-15-2011, 08:33 PM   #1
TurkJax
Drives: Z4 3.0si
Shifter knob won't go all the way in
I purchased 6-Speed Pattern(PN: 25 16 0 411 928) shifter knob and no matter how hard I push it, I can't get it all the way down.
Is there any way to do this? Any tricks? Suggestions?
This is really frustrating, there is always a 1 inch gap almost. Look at the pictures.
      02-15-2011, 09:52 PM   #2
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Wish I could help. I hate looking forward to getting something and then it doesn't work/fit. Hopefully someone here has a tip or two.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      02-16-2011, 09:05 AM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
is there room inside for it to go more in? anything blocking the hole? seems like a simple measurement would explain the problem
      02-16-2011, 09:23 AM   #4
3002 tii
3002 tii's Avatar
2286
you sure you slid it over the grooves? or there's no material caught in between the grooves?
Follow for latest mods
      02-16-2011, 11:11 AM   #5
TurkJax
Drives: Z4 3.0si
Yeah it is supposed to go all the way down. It measures to match.
I think it stops before getting to the tongue in the knob. I can see the tongue in it and I line it up with the grove on the stick but it stops before even getting there.
I wonder if the knob is bad and it is narrower. Can I beat on the knob and not damage anything?
      02-16-2011, 12:40 PM   #6
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
I wouldn't beat on it. You could damage whatever the shifter is connected to. I'm sure you've already applied enough pressure, and if it doesn't work, you should probably return it for a refund or an exchange.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
