      12-19-2010, 07:46 PM   #67
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
After reading this entire thread; Stock has all the HP I need - I am going to add the SS mid pipe if I can find a good price - If not I may get someone to fabricate one.
2006 Z4MC - #LL93158
      12-19-2010, 09:17 PM   #68
wrh3
Car Guy
wrh3's Avatar
31
Drives: 2005 MCS, 2013 Corvette 427
I don't know, even with the hassle I think it will still be worth it. The headers definitely add power, probably one of the best mods $$$ to HP. If my SES light is off with the new code, it will be perfect. If you don't want to trouble with "fitting" the headers you could pay a little more for the Turner MS headers or find a used set on the forum classifieds.
Bill- 2005 Mini Cooper S, 2013 Corvette 427
www.billswebspace.com/bmwindex BMW CCA Member # 389948
      12-19-2010, 10:23 PM   #69
mpower03
Drives: 08 z4 M Coupe
I have been running ebay 100 dollar headers for well over a year now, i also have the ess tune with o2 sensor delete. My o2 sensors have been tied off inside the engine bay the whole time. No CEL.
      12-19-2010, 11:03 PM   #70
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
I would never choose a full delete of the O2 since it's not recommended by any tuner out there, that is just me tho.
      12-20-2010, 06:28 PM   #71
wrh3
Car Guy
wrh3's Avatar
31
The DME came today around 3PM and I had a chance to take about 4 "trips" to see if the SES/CEL would light up......and it didn't.
Not sure if AJ had to update my software to be header specific (if wrong code was loaded initially) or if ESS had made changes to the header code file since my DME was flashed 2 years ago, but it seems to be working now.
      12-20-2010, 07:14 PM   #72
Diokaef
Engineer
Diokaef's Avatar
I believe that they just deleted completely your downstream O2 sensor^, Have fun hope you are happy with it.
      12-27-2010, 09:28 PM   #73
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
hehe, I just got my JVT headers installed last week
AA ECU header tune; no CEL light
I was lucky that my friend bought JVT headers for his E46 M3 before they stopped production. He ended up just giving me the headers for helping him swap OE headers back into his car (he's selling his car)
And since he's a close friend of mine, he offered to help me swap out my headers as well. All it cost me was a dinner meal
Will start a new thread once I get DynaPack and DynoJet runs in ^_^
Originally Posted by pokeybritches View Post
I was under the impression if you turn off your secondary O2s, it doesn't matter where they are placed because their readings are no longer used. You could zip tie them together if you wanted. Is this not the case?
You sir, are correct. My friend worked the O2 sensors for me so I'm not 100% clear as to how he placed them, but from what info he did mention, I believe you are correct.
      12-28-2010, 08:01 AM   #74
wrh3
Car Guy
wrh3's Avatar
31
About 500 miles now since reflash, still no SES light and the car is noticeably stronger with headers- I would do this before exhaust.
I don't think the post cat O2 sensors are turned off, but are turned down so that the delta between the pre and post cat sensors will ALWAYS show the cats as functional. If they were turned off we could simply unplug them and not worry about doing anything with them, that was my question for Roman before installing headers. The O2 sensor heater check still occurs, this is why they need to be plugged in- at least this is my understanding (which may be incorrect) with ESS code.
      12-28-2010, 08:16 AM   #75
F360C
Drives: E86 S54
Your thinking is correct in that they are still on but just "turned down". I know this because my brother has taken his car through a state inspection and the secondary 02's still read "ready"
07 Z4 M Coupe AW/IR
      12-28-2010, 09:00 AM   #76
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Just wondering, does the car emit a noticeable difference in smell from the exhaust now that 2/3 of the cats are gone?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      12-28-2010, 09:36 AM   #77
wrh3
Car Guy
wrh3's Avatar
31
I don't notice a difference in smell, but have some MagnaFlow cats stored if the secondaries ever need to be replaced.
I don't know if it's 2/3 of the cats now removed, the secondary cats are pretty large......large and efficient enough that there are no cat inefficiency codes thrown by stock DMEs when the post cat O2 sensors are relocated to the section 1 pipe. I believe the only purpose of the primary cats (US only) are to light off quicker and start working faster, it might be interesting to see just how much of a difference it makes once the secondaries are "hot".
      12-28-2010, 10:16 AM   #78
F360C
Drives: E86 S54
Mine def smells different especially on start up but not anywhere as bad as my friends m3 that has no cats at all
07 Z4 M Coupe AW/IR
      12-28-2010, 11:04 AM   #79
Starscream
Starscream's Avatar
I need to get a set of these
Hopefully the ESS tune holds as I too have an ESS tune (not for headers) that I'd like them to re-flash when I get the headers,
Was there a cost to re-flash your DME for the flash with header tune?
Obviously already paying $800+ for the first flash I'd hate to pay that again for the same thing bar header tune,
Imola Red Roadster
      12-28-2010, 12:17 PM   #80
wrh3
Car Guy
wrh3's Avatar
31
No cost for me other than paying the shipping back to them, but I was supposed to have working header code so they covered the return shipping to me (really they should have covered it both ways since it was their mistake).
I'm not sure what the fee is, or if there is one, for code changes. Best method of contact is to call and talk to Roman.
[EDIT] Based on this thread it looks like $100 for the flash + shipping for changes:
http://www.zpost.com/forums/showthread.php?t=399214
      12-28-2010, 02:19 PM   #81
Starscream
Starscream's Avatar
Ok cool thats not too bad,
I'm assuming I don't have the tune for headers, all I know is I have the ESS flash,
Not sure if that automatically includes turning down the O2 senors,
now just got to find a set of headers,
Imola Red Roadster
      12-28-2010, 02:39 PM   #82
wrh3
Car Guy
wrh3's Avatar
31
Now that you mention it, mine smells a little worse at cold startup since the cats have not had time to heat up and start working.....but once warmed up I don't think there is a significant difference. Definitely healthier and less smell than my no-cat cars
      12-28-2010, 04:06 PM   #83
mfanatic325
///M-fanatic
Taiwan
193
hah, mine's running no cats at all right now, so it definitely smells. But not nearly as bad as my MR2 turbo (also without cats)
Also, I DIY-ceramic-coated my JVT headers before I went through with the swap to help with increased flow
All I used was a high-temp header paint. It's called VHT (Very High Temperature) ceramic header paint. Available at parts stores like O'Reilly or Kragen, etc.
My friend and I like to DIY paint small items. It's pretty rewarding once it turns out nicely. I wish you guys should see my OE strut bar (which came as silver, even though I told them I wanted black finsh) that we painted to match the factory wrinkle finish. It looks spot on
      12-28-2010, 04:31 PM   #84
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
That's good. IIRC, the eruo Z4m doesn't have the cats in the headers and that's stock---so I suppose the cats that were removed arn't really necessary in order to have acceptable emissions...
      12-28-2010, 04:41 PM   #85
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Wish you luck with CEL. Mine didnt pop on till 500+ sometimes after I cleared them. Hope it's fixed.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      12-29-2010, 09:32 AM   #86
Starscream
Starscream's Avatar
Guys is there a good place to source these headers online?
Or anything like them?
Is it worth spending the extra on SS or AA headers?
Imola Red Roadster
      12-29-2010, 10:42 AM   #87
F360C
Drives: E86 S54
Which headers were you looking for? The JVT ones?
07 Z4 M Coupe AW/IR
      12-29-2010, 01:23 PM   #88
Starscream
Starscream's Avatar
Pretty much,
If they work as good as the others why not,
If its worth spending more on the AA or SS headers or Euro BMW ones then I will get those
Imola Red Roadster
