      07-28-2010, 03:21 PM   #177
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
Originally Posted by thekurgan View Post
CDV won't help that situation, it is only when the clutch engages, the valve is a one-way valve.
thank you, it is intermittent, maybe i need to refine my driving skills haha
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      07-28-2010, 04:04 PM   #178
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I had that happen a few times, usually on the brakes, with the new tranny mounts, it hasn't happened.
      07-28-2010, 04:05 PM   #179
Z4Murder
Z4Murder's Avatar
great to hear, i have a set of those on the way to me!
2007 TiAg ///MCoupe
      07-28-2010, 09:39 PM   #180
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
i never have a grind into 2nd but i do get rejected sometimes during very aggressive driving from 1st into 2nd. im trying to pinpoint when this happens, but im not quite sure. i might do the CDV delete and see if that helps.
I suggest Autosolutions SSK. It makes a big difference how it shifts.
      07-28-2010, 09:45 PM   #181
RobMCoupe
RobMCoupe's Avatar
60
For those that experienced 2nd gear grind, have you fix the engine mount bolts? I had the worst grind and noticed my engine mount bolt was bad. I have dealer looked into that. They said they reproduced it prior to fixing engine mount bolt. It was not grinding after they replace the bolts.
I have not grind since I change tranny mount, Autosolutions SSK, and Redline MTL. It is a bit notchy when cold, but I feel confident it will not go in the wrong gear.
I be happy to take anyone for a ride if you are in the Bay Area.
      07-29-2010, 02:05 PM   #182
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
Originally Posted by jragan View Post
I'd like to suggest that everyone who has the grind moves their seat forward by 1" (~2.5 centimeters) and reports back with how this has affected their grinding.
Just moved my seat today we'll see...
      07-29-2010, 09:08 PM   #183
jbh
jbh's Avatar
18
Drives: 2007 Z4M
I just replaced my CDV last night with the revised (fake) one. In normal driving it does make it easier to drive now, so far I like it.
      07-30-2010, 05:54 PM   #184
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I just had the UUC black neoprene trans mounts installed,
and the fluid changed to Royal Purple Synchromax.
To put it in simple terms.... HOLY SCHIT!!!!!
1st the mounts.
Even with the black neoprene there is some NVH transmitted to the cabin.
BUT, it is very mild.
You notice it a bit starting off and at a couple of points in the RPM range.
I kind of like it actually, it makes the car feel like even more of a raw beast.
Additionally my exhaust sounds even better.
If you like to keep things silky smooth you may find it mildly annoying.
I would be willing to bet that my co-pilot would not notice the difference though.
Performance wise, the shifter feels rock solid now.
It's amazing just how much movement there was before the upgrade & is now gone.
It makes finding the gates much easier and precise.
definitely a mod.
- can't wait for my next track day
The tranny fluid.
I could not be more happy with the difference that the Synchromax made.
It makes a HUGE difference in the way the tranny feels going through the gears.
It feels light and precise, much less rubbery.
The synchro engagement feels so much smoother.
It also feels like there are less losses in the tranny.
It's surprising but the car just feels like it is pulling harder.
On another note;
My tech suspects that the fluid has never been changed.
My car definitely had the 1200 inspection done, but it looks like they didn't bother with the tranny.
I should have suspected this because when I did the diff fluid previously & it looked bad too.
Guys... with these two changes the car drives soooo much better.
It has far exceeded my expectations.
      07-30-2010, 08:40 PM   #185
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
1st the mounts.
definitely a mod.
The tranny fluid.
On another note;
Pretty much what I have experienced as well, albiet with the Redline MTL. I do notice a small additional vibration, but only in the cold, after things warm up, I don't notice it. I do notice the gates clean and especially engaging 1st from a light, it just snicks right in. No denial to 2nd from 3rd, or 3rd from 4th, braking or otherwise. A worthy investment.
      07-31-2010, 06:29 AM   #186
RBull
Drives: 2007 M Coupe
Great feedback. Sounds like some must do mods.
1st the mounts.
definitely a mod.
The tranny fluid.
On another note;
      07-31-2010, 09:27 AM   #187
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
You can try it for yourself in a few weeks.
      07-31-2010, 10:16 PM   #188
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Will these Transmission mounts help with quieting down the whole drive train chatter problem known with these cars?
      08-01-2010, 08:59 AM   #189
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
No, those noises are features
      08-01-2010, 09:46 AM   #190
RBull
Sounds good. My mounts are ordered already though and I'm looking for synchromax. None available locally.
      08-01-2010, 09:48 AM   #191
RBull
LOL so true.
      08-01-2010, 12:53 PM   #192
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Sounds like you'll be great at marketing!
Seriously, Are you guys swapping these mounts out while under warranty? I'm just worry that should I have any transmission issues down the line, BMW will point to those aftermarket mounts to deny my claim.
      08-01-2010, 01:19 PM   #193
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
Hmm seems like my engine/trans movement theory on making the linkages move holds true. Even though I haven't had any issues with grinding I'll probably get a set just because I liked the way it felt and changed my last car when I swapped mounts out.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      08-01-2010, 02:22 PM   #194
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
As for the warranty, yes, it probably is some kind of void issue. I weighed that with the few transmissions being replaced (ZF Type-H), in these cars and the fact that I'll most likely be out of warranty if it does need work. The BMW mounts have always been too soft.
      08-01-2010, 04:15 PM   #195
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
IMO if they did void the warranty on that account it would be total BS in this particular case.
I'm all for the "pay to play" policy (change my springs and something breaks, it's on my dime; put a S/C on and bake a piston, my dime). I think they put the wrong mounts on the car. That's been proven given that the 3rd to 2nd denial issue is corrected with proper mounts (that issue should not exist). And there's pretty good chance of a money shift with the stock mounts in some scenarios (which we would get nailed for, even if the mounts caused it--good luck proving that). So replacing them actually seems the responsible and smart thing to do--especially if you track or autox the car. The stock mounts are probably fine for the non-M Z4, but way too soft for the ///M. It's an easy to correct parts bin selection error.
Since the swap is less than an hour to do a cheap insurance policy would be to keep the stock mounts and re-install them should the need arise. It's a bit sneaky, but in this case I don't see an ethical problem with it.
Now if you put semi-solid race only poly or steel and poly mounts on that's probably pushing it into the "pay to play range". Just opinion here guys, not fact, so it's up to your judgment of course.
      08-01-2010, 07:24 PM   #196
RBull
I'm with you in that line of thinking Finnegan.
      08-01-2010, 09:12 PM   #197
jragan
Imola Lover
jragan's Avatar
They can't just void the warranty unless they prove that your modification was absolutely the cause for some problem that would normally be covered.
Hers: 997-1 C4S: Pics
      08-04-2010, 12:14 PM   #198
PatJags156
PatJags156's Avatar
Drives: 335i Convertible
Very long and educating thread.
So where did we net out on a possible solution?
I have a 3.0si and I have a grind from 1st to 2nd. Also, when I bring the car from 4th or 3rd to 1st at a light while standing still I hear a loud clunk noice.
Would the solution for me be? New trans fluid and something else?
