      02-28-2022, 12:51 PM   #1
SunUpTopDown3
Backroad Warrior
SunUpTopDown3's Avatar
Drives: Z4MR
Z4M specific track prep checklist
With track events around the corner. What is everyone's Z4M specific track preparation routine? General prep checklist items are obvious, but I'm asking more on what/how to prepare a (mostly) stock Z4M, specifically?
Fueling: run with full tank? or 3/4? 1/2? How often to fuel up? Octane booster?
Any specific track alignment specs, or, keep stock?
Any quick reversible weight reduction tips?
Any cooling upgrades?
Any trans fluid upgrades?
Brake pads: are stock ok, or, need upgrade?
Another thread posted that racing brake fluid (castrol) is recommended, rather than Ate typ 200. Yes/no?
      02-28-2022, 05:38 PM   #2
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
I would say that if you’re new to this, don’t over think it. Make sure your car is in good condition and you keep up on the maintenance. Run what you brung and figure it out as you go.
      02-28-2022, 06:52 PM   #3
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Originally Posted by Michael9218 View Post
I would say that if you're new to this, don't over think it. Make sure your car is in good condition and you keep up on the maintenance. Run what you brung and figure it out as you go.
Seconded. ATE DOT4 fluid is a solid choice for street and track. If you are hard on the brakes the stock setup can definitely leave break pad deposits, PFC08s are a good in between pad (still squeak).
The gas tank light on our cars is not as reliable on track. It could be a few more laps, could run out this lap. Prepare accordingly
Otherwise make sure fluids are in good standing, when in doubt have a BMW shop (indy) do a pre-track inspection.
      03-01-2022, 12:14 PM   #4
SunUpTopDown3
Backroad Warrior
Drives: Z4MR
So I figured. Z4Ms are mostly track ready in stock form. You could get crazy with it or not. I really don't want to go overboard.
Tags
autocross, hpde, scca, track
