      11-26-2008, 12:35 PM   #1
ANDIES
Drives: Z4 SI O8
DSC
Hi am am ne wz4 o8 owner how do you tell if the DSC is on or off it is says DSC on the dash does that mean it is on or off?
      11-26-2008, 12:45 PM   #2
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
I think the regular Z4 (non M) has the same system as the 3er.
If that's the case, this thread from E90 post basically sums up the DTC/DSC explanation.
      11-26-2008, 12:45 PM   #3
MerLOW
Drives: 05 Z4 3.0i
2005 Z4 3.0i  [9.00]
As a default, the DSC is always ON unless you manually turn it off via the console mounted button.
2005 Z4 3.0i roadster, Merlot red metallic, beige int & top, sport, premium, heated M seats, xenons, Aux input, OEM strut brace, OEM hard mount wind diffuser
      11-28-2008, 02:03 AM   #4
izzy
South Africa
13
Drives: ///M Coupe
Is there a way to get DTC on a ///M Coupe?
Why did the ///M not get DTC?
      11-28-2008, 11:11 AM   #5
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
///M Models have viscous LSD, which is superior to DTC in my opinion.
      11-28-2008, 12:19 PM   #6
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
The standard DSC mode on the ///M seems as aggressive, if not slight more so than the DTC mode on the E90 (ie in allowing wheel spin).
