      11-25-2008, 05:50 PM   #1
reRESERVEDFX
(oO (||||) (||||) Oo)
reRESERVEDFX's Avatar
Drives: 06 BMW Z4 3.0i 03 BMW M5 DINAN
BMW Z4 05/06 Models Acceleration
Hey,
I'm just wondering how big is a difference between BMW's 3.0si 255HP and 3.0i 235HP engine acceleration wise? Are there big gaps in 0-60 MPH time in both of these cars?
Also, stupid question but what's the average 0-60 time for an E46 M3 manual?
I'm considering another BMW and I think that when 235 is plenty for a lightweight Z4, the 5er is gonna be too heavy and I better be off with 545i or just go with 06 330i (255HP)
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red
      11-25-2008, 10:17 PM   #2
Mikewarlover
Mikewarlover's Avatar
Drives: white
I would go for an E46 M3 if u are not considering the M coupe or roadster M3 manual realisticly get around 5 to 5.5 but with extremely good tires and a hard but effective launch i believe E46 m3 can get like 4.9 zero to sixty.
      11-26-2008, 12:42 AM   #3
reRESERVEDFX
Oh no I'm not getting an M3, I was just wondering since I've read somewhere that they got stock M3 from 0-60 in 4.7s which seemed quite unbelievable.
I was just wondering whether there's significant change in acceleration between BMW's 3.0i 235HP engine and 3.0si which is 255HP. I mean 20HP seems like slightly significant boost in a car of that size. It also bothers me because I'm thinking about a new 5er and I'm still wondering whether 235HP is gonna be enough for such a big car.
      11-26-2008, 04:59 AM   #4
rc'Z
Drives: 2009 335i Convertible
It would depend on what you think significant is. It might be as much as 1 to 2 tenths of a sec. Not likely your calibrated butt accelerometer will tell the difference.
      11-26-2008, 08:06 AM   #5
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
Several factors to consider incl weight of car, gear ratios, axle ratios, etc. If you're considering acquiring one of two different model 5's, I'd suggest you drive the 2 models and/or post on a 5 forum to find someone with experience.
      11-26-2008, 11:40 AM   #6
m3griff
Drives: Z4 3.0Si
Sometimes looking at Dragtimes database can help. Not much for stock Z4's (the ones denoted with # on them), but it appears that the 06+ si is slightly quicker and faster in the 1/4 mile than the earlier Z4's. Not enough data, but there is probably a small gap. It does not seem enough to really worry about if you find a car that has the colors and equipment you want.
http://www.dragtimes.com/BMW--Z4-Drag-Racing.html
Jeff
      11-26-2008, 12:04 PM   #7
Mikewarlover
Drives: white
Jeff
By earlier Z4 do u mean 2.5 i won't believe that a 3.0 z4 with 230hp can't beat a si even auto ones.
      11-26-2008, 01:29 PM   #8
CalRick
Drives: '15 M235 & '95 M3 tracktoy ;
2016 X3 Xdrive28d  [0.00]
2015 BMW M235i  [0.00]
1995 BMW M3  [0.00]
I wouldn't expect there to be a big difference between the 3.0si and the earlier 3.0i (both are quite quick) - probably 1/3 to 1/2 the difference between the earlier i and the M. Given the lack of reliable and comparable data between the two when I was looking, I mostly looked at the fatter torque curve along with the extra 30 bhp of the 3.0si as the tipping point on my decision. Given its character as a sports car, I'm not as interested in 1/4 mile or 0-60 clutch burning times as I am in how it works on the road. The wider power band between torque peak and power peak indicates that the additional power is usable power rather than just some added top end for bragging rights.
      11-26-2008, 05:29 PM   #9
knuklz
Drives: 2006 Bmw Z4 3.0Si
I would think that there would be a noticeable difference in acceleration
      11-26-2008, 09:22 PM   #10
m3griff
Drives: Z4 3.0Si
I meant to compare a 3.0i with a 255 hp 3.0si. I bet 0-60 are pretty close (.1-.2 sec) given that 1/4 mile trap speeds seem to only be about 2-3 mph better for the si. Bottom line is that the day-to-day driving won't feel that different.
Comparison to a 2.5 is a completely different matter.
      11-26-2008, 09:25 PM   #11
Mikewarlover
Drives: white
Yea depends on your situation. My friend got an I because there wasn't a good si he wanted so he went for the I. Honestly i struggle to find them any different. its like the new E92 328 i had compared to the old e90 330. In race obviously the 330 isgonna be slightly faster but both ain't that fast.
      11-27-2008, 06:52 AM   #12
m3griff
Drives: Z4 3.0Si
For me, between the 3.0i and si, I would go with a car that had the colors and options I wanted - definitely the sport package. Also condidering miles and condition.
      11-27-2008, 10:19 AM   #13
epbrown
epbrown's Avatar
When it comes to improving 0-60 times, it pays to pay less attention to horsepower and check to see if the car maker changed the gearing or improved torque numbers - that tends to be where they make their acceleration gains. In the case of the 2005 3.0i over the 2006 3.0si, I think BMW went from a 3.07 final drive to a 3.23 (3.46 for the coupe). Buy the 2005 3.0i and spend $400 on a 3.46 rear end, you're back in the game.
Similar effect with the E46 M3 compared to the E90 M3 - while the 30ft-lbs they added helps the car off the line, they also changed from a 3.62 final drive to a 3.85. Add in the fact the new car weghs more, and you can see why swapping a 3.91 or 4.10 final drive would make the E46 fast enough for you to not be able to tell the difference without instruments.
As for the E46 M3's times. Factory quoted figure was 5sec for 0-60, most magazines got 4.7sec. The new M3 is quoted at 4.7sec by BMW, most mags get 4.4sec.
      11-28-2008, 06:30 AM   #14
rc'Z
A little bit of Motor Trend Homework for you:
2003 Roadster 225hp: 0 - 60 6.1 sec; 1/4 mile 14.5 sec 96.6 mph.
2007 Roadster 255hp: 0 - 60 5.1 sec; 1/4 mile 13.8 sec 100.1 mph.
2006 M Coupe 330hp: 0-60 4.9 sec; 1/4 mile 13.4 sec 104.2 mph.
Road and Track also reports:
M Coupe at 0 - 60 4.9 and 1/4 13.4 105.3.
2003 Roadster 0 - 60 5.6 and 1/4 14.4 95.7.
Car and Driver did post a 4.6 and 13.2 107 for 1/4. M Roadster by the way.
Even in day-to-day driving, not much difference between S and Si And as a matter of published fact not much difference in day-to-day between Si and M.
      11-28-2008, 01:43 PM   #15
Mikewarlover
Drives: white
I ve seen 13.8 quater mile times for Si before yet i seriously think thats with a very hard launch doing a respective amount of damage on the tranny. In fact i hardly believe the extra 30 horsepower is gonna make that much of a difference.
      11-28-2008, 02:29 PM   #16
Burt Reynolds
Burt Reynolds's Avatar
53
Drives: 2007 M Coupe
I would argue BIGTIME difference in day to day driving with M vs others. Sorry. This sort of comparison is the danger of magazine racing as it oversimplifies way too many important variables. Now they are all FANTASTIC cars but definitely different and worth a test drive to determine your individucal preference.
      11-28-2008, 05:10 PM   #17
epbrown
epbrown's Avatar
This I don't get - BMW's factory time is 4.9sec and they're known to be conservative with their times. Every other BMW model ever tested by a magazine gets a better time than that quoted by the factory except the M Coupe.
      11-28-2008, 05:13 PM   #18
reRESERVEDFX
I also doubt that 20HP makes so much difference in the exact same car. I'm more lenient to the epbrown's opinion about final drive ratios but it still doesn't explain how 3.0i can get a second faster from 0-60 than 3.0si. Today I did 2 hard on starts and managed to get about 5.2 and 5.4s 0-60 times respectively. Stock 05 Z4 3.0i.
      11-28-2008, 05:37 PM   #19
knuklz
Your 3.0i is quicker than an Si Stock? Did I read that incorrectly or did you mess up somewhere? and if so.. then whats the point to purchase an 3.0Si if there's not much difference in power?
      11-28-2008, 05:41 PM   #20
Mikewarlover
Drives: white
Si was really introduced to improve the Roadster a little bit over time. And M is on an entirely different level as Si to drive. M is just so brutal and so much more exciting and significantly faster when u rev it a bit.
      11-28-2008, 05:43 PM   #21
m3griff
Drives: Z4 3.0Si
I think the general them of many of these posts has been that there is no reason to pick an Si over an 3.0i, unless you have to have more warranty or certain colors/equipment.
I would agree with the earlier post that the M is a whole different animal - numbers notwithstanding. The M has an entirely different feel to it.
Jeff
      11-29-2008, 02:48 PM   #22
knuklz
wait a minute whats the 0-60mph on a 3.0Si? If you post please have actual number not some bull crap Cheers!
