      10-10-2015, 03:30 PM   #1
3002 tii
3002 tii's Avatar
2282
Dead ECU, any INPA Users Here?
I did headers a while back and had a tune from AA that turned down the o2 sensors for inspection purposes. Everything was fine but I would get a weird surging idle. AA offered to revise the tune and I figured may as well purchase their new flash loader for quicker uploads. Big mistake.
After following all procedures and uploading the tune, my car won't start. Turn the key and the engine cranks but it won't turn. I the unplugged the AA flash loader and hooked up my OBD diag device and even that can't connect to my ECU... wtf?!
I then tried to recover my ECU using my backup tune but still same result. And I also noticed this time the AA flash loader showed "vehicle manufacturer ECU hardware number shows ????"
For those familiar with INPA, can I recover my ECU? I've never used it before but at this point I'll try anything. Did some research online and seems like INPA may be able to recover if I realign the DDE and EWS.
Follow for latest mods
      10-10-2015, 04:34 PM   #2
GuidoK
GuidoK's Avatar
10843
Drives: Z4 3.0i ESS TS2+
INPA doesnt flash ecu's
BMW uses other programs for that. They have 2 but I'm not sure about the difference.
The bmw flash tools are not exactly user friendly.
INPA is diagnostic with some adjustment on components.
But if you can read your cpu with inpa, your ecu can probably be saved.
I have no idea if the bmw flash tools will be able to handle your backup file. (I doubt it)
      10-10-2015, 04:42 PM   #3
3002 tii
3002 tii's Avatar
2282
Flash or not, my question was really asking if INPA can be used to fix my car using those few adjustment capabilities? I've read others with similar symptoms stating it was an immobilizer issue and "realigning the DDE ans EWS" using INPA allowed the ecu to start communicating again.
      10-10-2015, 10:24 PM   #4
3002 tii
3002 tii's Avatar
2282
Mini update but I'm convinced my ECU is bricked. Not sure how it happened as my voltage was good and the laptop never froze. *Sigh*
      10-11-2015, 07:58 AM   #5
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
I'd try to get a hold of AA. I bet they will be able to give you some advice. I doubt your DME is toast. Worst case though, you might have to send your DME to them to reflash it.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      10-15-2015, 11:37 AM   #6
sudoer
Drives: 2004 Z4 3.0i, 2006 X3 3.0i
You can use WinKFP to try to reflash your DME.
      10-16-2015, 06:40 AM   #7
3002 tii
3002 tii's Avatar
2282
I sent in my ECU, EWS (what a pain to remove) and key to AA. They're going to recover and reload the map and send back. Just no idea how long it'll take because they need to get a Z4 3.0 in their shop to test before shipping back to me.
      11-06-2015, 09:03 PM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Glad to hear that you are mobile again.
Sounds like it was a real PITA.
      11-06-2015, 10:02 PM   #9
3002 tii
3002 tii's Avatar
2282
It was but what can you do? Anyways if anyone ever has a fried or bricked ecu, I highly recommend shipping it to RPM Motorsports. They were able to able to recover my ecu back to stock, really professional crew over there.
      11-07-2015, 07:31 AM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks, added to subscribed
      11-07-2015, 12:09 PM   #11
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
Glad to hear it was fixed.
Will you go for a tune or will you keep it stock now once you got it fixed?
      11-07-2015, 02:08 PM   #12
3002 tii
3002 tii's Avatar
2282
They "owe" me a tune so I may ask for a map that's same as factory but with o2's turned down so I can pass emissions. I'm hesitant for a performance tune since I no longer have the weird idle. That's the thing with off the shelf tunes, n52 on z4 isn't same as e90. I'd imagine its same as the s54 tune for the m3 won't work as intended on the z4. Maybe down the road I'll get a custom dyno tune from Frank Smith.
      11-07-2015, 05:23 PM   #13
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
Probably a wise move. I know the S54's in the Z4 have a newer version of the Siemens ECU than the E46's and the same goes for the Bosch ABS unit. Kinda wierd they use different ECU's for the same kind of engine.
I did some research looking into the E90 with the N52 and the E87, they have the same version of ECU as the Z4's. But the N52 was used in many different cars so the ECU might vary.
      11-07-2015, 06:25 PM   #14
3002 tii
3002 tii's Avatar
2282
Ecu hardware are same for n52 but map settings must differ considering the weird idle I had only begun after the tune. Either way just happy I got my car back although I missed the last month of track season.
      11-16-2015, 02:57 PM   #15
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I am about to contact RPM Motorsports to rebuild my e36 M3 DME. I hear they are the best because I have another company to check my DME and they screw it up. Now I have 2 VINs and it is an automatic.
      11-17-2015, 09:10 PM   #16
3002 tii
3002 tii's Avatar
2282
Tell Zach Daniel with Z4 referred you, he'll the excellent care of you
      11-02-2020, 12:38 PM   #17
CrazyOneToo
1999 E46, 2002 E53, 2007 E85....all in progress
Drives: 2007 Z4 3.0Si Roadster
Hello all. I just used BimmerLabs files and WinKFP to flash my 2007 Z4 N52 software from a
3.0i to a 3.0Si and now the car cranks but wont start.
Any help would be greatly appreciated!!!
_
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress.....
      11-03-2020, 12:02 AM   #18
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
_
It could be several things, but a checksum error is most likely. Flash a stock tune with WinKFP and see if it solves your issue.
      11-03-2020, 01:28 PM   #19
CrazyOneToo
How would I check for that issue? Here is what I saw.
      11-03-2020, 04:27 PM   #20
Gamb1t
Gamb1t's Avatar
Drives: 330i,X1,Z4,Solstice GXP, RX-8
Doesn't the 215hp 3.0i n52 has different maps than the 3.0si 260hp n52... amongst other parameters?
      11-03-2020, 06:36 PM   #21
CrazyOneToo
You can get custom tunes for catless headers, high octane gas,
and bypassing O2 sensors.
      11-03-2020, 07:07 PM   #22
pokeybritches
2006 BMW Z4M  [8.50]
Did you try writing a stock tune?
