      03-01-2016, 08:50 PM   #1
Nuzguy
Drives: 2006 BMW Z4
Looking to put M3 19 inch wheels and tires on my non-M Z4
Hi folks, found a great deal on these but not sure if they will fit my 2007 Z4. Mine is a non-M.
Tires on the front are 235/35R19
Tires on the rear are 265/30R19
Thoughts?
      03-02-2016, 07:45 AM   #2
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
From the tire sized I assume you are referring to the 19s off an E9x generation M3. If so they will not fit.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black
F06 640iX - Tanzanite Blue/Amaro Brown
K66 ///M1000RR - Competition
      03-02-2016, 08:09 AM   #3
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
The tires won't fit stock rims.
If you have aftermarket rims, it could fit...but the width of the rim and offset would need to be known to confirm.
I'm looking at the same sizes for my non-M Z4 but with aftermarket rims 8.5" front and 10" rear.
      03-02-2016, 03:12 PM   #4
Nuzguy
Drives: 2006 BMW Z4
They're off an E46 M3. Not sure of the back spacing. I'll post a pic ASAP.
      03-02-2016, 03:25 PM   #5
3GFX
3GFX's Avatar
Check the back/inside of the rim (if you can) there will be the specifications.
      03-02-2016, 03:58 PM   #6
Nuzguy
Drives: 2006 BMW Z4
Here's a picture of the wheel and tire. It' is a stock M3 wheel.
http://images.craigslist.org/00i0i_q...XR_600x450.jpg
Thanks for the help.
      03-02-2016, 04:22 PM   #7
Steeler
Steeler's Avatar
2429
Check this site for the wheel.
Some wheels have the specs listed
http://www.bmwstylewheels.com
      03-02-2016, 07:33 PM   #8
Nuzguy
Drives: 2006 BMW Z4
fantastic site! Offset looks to be 47 on the front and 26 on the rear.
      03-03-2016, 10:29 AM   #9
3GFX
3GFX's Avatar
Your tires are going to poke from the looks of these specs.
      03-03-2016, 08:43 PM   #10
Nuzguy
Drives: 2006 BMW Z4
thanks 3GFX. Do you mean poke out past the fenders? i assume that's it. i will have to try them and see how close it will be.
thanks again!
      03-04-2016, 11:18 AM   #11
3GFX
3GFX's Avatar
Yea, think they will poke past your fenders. Take a pic when you try em out.
